 Post subject: WD Eangle 200JD-55HBB0 FW in NEED
PostPosted: May 20th, 2009, 14:47
anyone have this?
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: WD Eangle 200JD-55HBB0 FW in NEED
PostPosted: May 20th, 2009, 15:09
Isn't that Falcon?
PostPosted: May 20th, 2009, 17:32
It's Eagle. I think Falcon has not been released
Please provide FW revision
PostPosted: May 20th, 2009, 17:57
I have a handful of Falcon drives in the basement... As I recall most if not all of them are Apple branded.
PostPosted: May 20th, 2009, 19:07
It's Eagle.
And the right model is WD200JD-55HBB0
F/W 08.02d
XRONIS
T3 Professional Data Recovery
http://www.t3-recovery.com
PostPosted: May 20th, 2009, 20:23
Kyrios,
I think you mean WD2000JD . . .
http://www.datasaversllc.com
PostPosted: May 20th, 2009, 21:43
I'm wondering how do you distinguish Falcons of Eagles
Don't tell me "Acelab said take two letters from the model and use our fancy table" 'cause they wrong
PostPosted: May 20th, 2009, 22:56
I've seen the model name embedded in FW modules. That ought to settle it, if you can view it . . .
PostPosted: May 21st, 2009, 0:44
I'll post specifics when I get to work tomorrow.
PostPosted: May 21st, 2009, 13:25
Well, I stand corrected. Apple branded drives typically also carry an abbreviation of the family name with an A or S at the end (i.e. HAWKA, MERCA, etc.) These particular drives are labeled FALCA but I guess Apple just labeled them incorrectly, as the firmware reveals they are indeed Eagle. I've never seen it be incorrect before, so that's what I was going off of. I've also seen a few websites describing xxHBxx drives as Falcon, so I wonder where they all got the wrong info from?
PostPosted: May 21st, 2009, 14:24
It's EAGLE I think and I have a backup of this FW
Good luck
PostPosted: May 23rd, 2009, 19:20
Interestingly enough I see that one of the aforementioned websites listing HB drives as Falcon has changed it to Eagle sometime in the last two days. :mrgreen:
PostPosted: May 24th, 2009, 15:13
Which site are you talking about?
PostPosted: May 24th, 2009, 16:54
PMed
