 Post subject: Need Any NVR for HDS721680PLA380
PostPosted: May 20th, 2009, 5:14
I need NVR (the version is not imnportant) for HDS721680PLA380
Someone have it please ?
Thank You
 Post subject: Re: Need Any NVR for HDS721680PLA380
PostPosted: May 20th, 2009, 8:11
I have a good drive, but AFAIK it isn't supported by PC3000, so the only way I know to get NVRAM is to remove the EEPROM and copy it.
http://www.datasaversllc.com
PostPosted: May 20th, 2009, 8:21
Why it is not supported ? If you have PC3000UDMA the Hdd is full supported.
Can you verify ?
Thank you
PostPosted: May 20th, 2009, 12:38
I tried it on one of our PC3000 UDMAs that does not have the latest update. I couldn't find the appropriate family in the menu. I have another that is current but it is at a different location.
What setting works for you with this drive?
PostPosted: May 26th, 2009, 5:25
I have NVRam for hds728080pla380. if required then let me know.
Users browsing this forum: Google [Bot] and 122 guests
