HITACHI/IBM - Head change
June 5th, 2009, 17:58
Hi to all,
I have received some Hitahi disk with head problem.
- Hitachi 60Gb . two heads - donors with the same MLC, when i change the heads the disk it click click don't have ID, but if i put the heads from the patient in the donor disk i can have ID, when SA Test it give error in all the copy1, so i think the head 1 from the patient is BAD, but why can i use the heads from the patient in the donor, and can not use the donor heads in the patient?
- when i put again the heads from donor in the donor disk it work and i can HAVE ID.
- Have also other 80Gb, 4 heads, that the head 2 get out off the head stack, also have the MLC match and other that dont match but the disk "click click click" do not have ID.
I have made somes hitachi disk just change the heads and matching the MLC + Model, but in this time i am not making it.
Is there any thing that i miss to do ?
Thanks for the help.
Re: HITACHI/IBM - Head change
June 5th, 2009, 18:41
If you can place the donor heads back into the donor and they still work there is two scenarios:
Incompatible headstack or critical damage to the SA.
Check for damage. The scratch may be too small to see by eye, which is why it isn't killing heads (yet)
