 Post subject: Fujitsu MHV2080BH ATA password
PostPosted: May 29th, 2009, 23:46
Is there any software to remove ata password from this disk? I dont have pc3000 , tried hdat2 but didnot worked.Any help appreciated.
 Post subject: Re: Fujitsu MHV2080BH ATA password
PostPosted: May 30th, 2009, 1:08
NO.
PostPosted: May 30th, 2009, 13:30
Such drives are not easy to remove the password if you don't know the password
Our company can do that if you interested but it's not for free
PostPosted: May 30th, 2009, 14:56
I gave precise answer to precise question : is there a sw... etc. : NO. Of course is possible but not for free.
PostPosted: May 30th, 2009, 16:01
I presume he means free or solution cheaper than buying a new HDD? If so, then no.
If data is required, then there are solutions, but not free.
PostPosted: May 31st, 2009, 7:52
Hi Thank you all of your for your kind concern.
Its an old 80gb disk from a friend. No data is to be recovered & disk has to be utilised. I am into data recovery & know details of ATA password but my company does not own pc3000.
I thought security erase may work , so tried fujtool v0.4 / Atapwd / Victoria v 4.46 ( which has unlock option but gave error drive diskconnected thorough pio mode).
Also tried hdderase from CMRR , nothing worked out. Seems PC3000 is the only solution as salvatiodata is not having fujitsu solution.
thank you
PostPosted: May 31st, 2009, 9:03
Unlock with erase : a pro would charge only few bucks - with or without PC3K
PostPosted: May 31st, 2009, 23:16
ZOC and couple commands :roll:
PostPosted: June 1st, 2009, 2:42
Hi kamen
Thanks a lot .
PostPosted: June 1st, 2009, 4:04
Sorry, what is ZOC?
PostPosted: June 1st, 2009, 13:49
You can try below product. I guess license is per usage. If you wish to unlock with erase, it is free by one of their tool.
Your model is listed as supported in their website. Hope this helps. http://www.hddunlock.com/drives/fujitsu/
Hari
PostPosted: June 1st, 2009, 20:53
platter,
ZOC Terminal Emulator and Telnet/SSH Client
PostPosted: June 2nd, 2009, 0:50
Hi hnmurugan
Thanks a lot. I will give it a try & post results.
PostPosted: June 2nd, 2009, 4:03
Tried Hddunlock wizard , but since disk is not initilized in windows , wizard is unable to find it.
It is connected to native SATA por on Asus A8N SLI deluxe motherboard is well getting detected in BIOS & Disk Management but wizard is unable to locate it.
Now what to do? Can someone from AFF or HDDunlock help?
PostPosted: June 2nd, 2009, 4:21
Can i issue ATA command security Eraser for this drive? Will it work? Can someone give hint how to give this command?
learner
PostPosted: June 2nd, 2009, 5:41
If Mhdd won't help in this case, only special command or a pro can.
PostPosted: June 2nd, 2009, 7:59
I am afraid it may due to sata controller issue. Why don't you try intel chipset mother board instead of Nvidia? And it has to be connected as master. i have done it before. Refer to attached screenshot for same model.
Hari
PostPosted: June 2nd, 2009, 12:53
Only if you provide correct password
PostPosted: June 4th, 2009, 1:21
Thanks a lot hnmurugan & Doomer , Lets hope to make it using intel chipset.
Users browsing this forum: No registered users and 157 guests
