 Post subject: Need HELP
PostPosted: June 2nd, 2009, 3:32
Hi everyone,
I have a Samsung SATA SP0812C 80G that has a bad sectors. I checked with MHDD is on a few block at front only has a bad sectors but after i "ERASE" it from sector 0 until end of sector with MHDD the HDD is becoming bad sector from sector 0 to end of it. Please help me how to fix this. when i "ERASE" again the drive still running on 50000 - 60000 kb/sec. But if i check again a whole part still bad sector. Many thanks for help.
 Post subject: Re: Need HELP
PostPosted: June 2nd, 2009, 5:44
Drive need to be serviced. Are you sure it is not ATA LOCKED and you get ! Not bad X ?
PostPosted: June 2nd, 2009, 10:09
Thanks BlackST. It's not lock By ATA Password but sure it's bad with xxx marks. How could this happen? Can i fix this with MHDD? i'm using MHDD 4.6. First it's only a few of block that has a bad sectors at the front, but after i "ERASE" the sector to the end, i check the drive full of bad sectors. Please help. Thanks.
PostPosted: June 2nd, 2009, 10:15
No. It's beyond your possibilities with 'free' tools.
PostPosted: June 2nd, 2009, 10:25
O boy... what your suggestion?
PostPosted: June 2nd, 2009, 10:33
Where are you located? I can suggest you a pro in your area that can fix the drive for a reasonable price.
PostPosted: June 2nd, 2009, 10:42
If the data on the drive has no value, why not just spend the $50 to replace it?
PostPosted: June 2nd, 2009, 11:31
So why this forum used for? I said that my harddrive has only a few bad sector at the beginning then it's becoming whole of part because i'm ERASE it. I supposed there's a solution for this. I can buy it, i just want to share if this happen to others hope can help them.
PostPosted: June 2nd, 2009, 12:29
Oh no, not again !
PostPosted: June 2nd, 2009, 15:06
PC3000 $10,000
Training course $3000
Drives for practise $200
"Know how" - Priceless :D
www.datarecoveryne.com
PostPosted: June 2nd, 2009, 15:21
There are things you can't buy... for everything else, MASTERCARD. :mrgreen:
PostPosted: June 2nd, 2009, 15:49
Hard drive can read and hard drive can write, so they call heads
read/write heads.
In your case appears as if your samsung can read but writing is BAD.
Like your drive has a broken leg, or possibly the nerves to one leg
are in need of a doctor or the brain is not talking nicely to the one leg.
I think one leg is broken, just a little, like a fracture so it cannot write
very nicely.
If you need the data, walk on one leg and just do reading.
If you want two good legs, buy a new hard drive.
PostPosted: June 2nd, 2009, 16:00
@derp... are you really sure ?!? :shock:
@dimaz : I have the know how to fix your drive (if there is no physical problem, anyway) - but I am thousand miles away. If you post your location maybe we can suggest a pro near you that can fix it for few bucks.
If this last option doesn't suit your needs... well, nothing else to say.
PostPosted: June 3rd, 2009, 12:23
Dimaz wrote:
Hi everyone,
just format it within your O/S the sectors will be mapped out ... Simples!
PostPosted: June 3rd, 2009, 12:35
No, GURU, it is in need of selfscan! I suggested to contact a specialist in his area.
PostPosted: June 4th, 2009, 4:39
ahum.... I should read the whole message LOL..... Can I say? "You Need A PRO" !!!! :lol:
Users browsing this forum: No registered users and 277 guests
