 Post subject: Help with ST340014A please ...
PostPosted: May 25th, 2009, 15:42
Could some please provide the part value or written info stamped on the inductor on the circuit board that connects to pin 8 of the 2P102 power trench mosfet IC. I think it is a ferrite device somewhere between 1 and 10 uh. Thanks :)
 Post subject: Re: Help with ST340014A please ...
PostPosted: May 25th, 2009, 15:44
Why, is it broken ?
PostPosted: May 25th, 2009, 21:47
Its missing. :(
PostPosted: May 26th, 2009, 0:42
This is a ferrite coil marked 3R3, most likely 3.3µH.
Jono
http://www.datasaversllc.com
PostPosted: May 26th, 2009, 19:20
Thanks Jono. I'll give it a try
Regards :)
PostPosted: May 31st, 2009, 10:56
The 3.3 uh done the trick. The drive is upl and passes all diags. The -5V supply looks good. Thanks again :D :D :D
Users browsing this forum: Majestic-12 [Bot] and 142 guests
