 Post subject: My hard disk shutdown my pc
PostPosted: May 31st, 2009, 22:50
I need help, I'm using Seagate 120GB PATA hard disk.
When I connect the hard disk to the Mainboard, the CPU cannot turn ON.
I already try with other pc.
I need to recover the data.
What is the root cause of the hard disk failure?
Can i just change the PCB?
 Post subject: Re: My hard disk shutdown my pc
PostPosted: May 31st, 2009, 22:56
Search the forum for TVS.
PostPosted: June 1st, 2009, 2:12
The root cause is crap power supply.
PostPosted: June 1st, 2009, 2:39
TVS? ok. By the way i've just change new power supply (maybe the new one crap...)
PostPosted: June 1st, 2009, 4:00
I think you have a short circuit in your hdd pcb. Check if there's any burnt mark.
PostPosted: June 3rd, 2009, 17:10
Banned User
Hi ,
Please replace your pcb and before replace the pcb please check the model no and correct firmware from donor drive..please do this to obtain the data.
PostPosted: June 3rd, 2009, 17:43
withyou wrote:
Hi ,
Disagree!
Plese don't suggest anything when you don't know what you are saying!
In this mode, the pcb swap is not enough.
results-the-yourself-solutions-t11912.html
Janos
PostPosted: June 3rd, 2009, 17:52
Banned User
Hi ,
I just give the first suggestion, as i know as per best of my knowledge ,and the user is the best judge after replace the pcb to get the data back or not... and to replace the proper pcb with proper donor drive selection there is no harm as, we all do at our first step..
PostPosted: June 3rd, 2009, 18:36
Banned User
Hi friend ,
The root cause is crap power supply, but to solve your problem, you have to replace your pcb first with proper model no./firmware or good to find same part no..
and after replace the pcb may be you can get the data back .please let me know or send the problem after replacing the pcb .we all are with you to retrieve your data back.
PostPosted: June 4th, 2009, 2:24
Withyou..
As N.C. said,
Please don't suggest anything when you don't know the hell about it. With one wrong move, and the rest of the drive can easily be friend.
To Zack,
In this seagate model, a simple PCB swap very unlikely to work. You should rather check the continuity at the TVS diode, and remove the bridging.
I just hate spammers...It was a Spammer, who ruined my life!
PostPosted: June 4th, 2009, 3:40
withyou wrote:
Hi ,
As i see, "your knowledge" is very low. :mrgreen:
So, please don't suggest anything until READ a lot and learn from this forum...
I suggest for you to start @ this point:
Janos
PostPosted: June 4th, 2009, 16:24
Banned User
N.C. wrote:
withyou wrote:
Hi ,
Janos
Hi Friend,
We are here to give some suggestions or to share/distribute our experience may be i am having very small experience as you can say to rectify the problem ..i start my work with st225 20mb at that time we use debug to rectify the 20 mb /st 341 40 mb hard drive as that was the year of 1991..
Today i am having my own clean room with approx 20,000 Hard Drive (for me to select the proper donor drive )at my own stock with all the world wide utilities including latest gadgets .
I just share my experience with you as these are very small problems .
As i want to help the user in a very simple way .
PostPosted: June 4th, 2009, 16:45
no comment. :)
PostPosted: June 4th, 2009, 16:52
Sometimes they come back... :D
Users browsing this forum: Google [Bot] and 115 guests
