 Post subject: Corrupt files NTFS
PostPosted: October 30th, 2020, 9:32
Hello, guys! I faced with a problem: I had the "Storage Spaces" on Windows Server, but suddenly a disk broke, therefore to remain only RAID1, which was created early. In this case should have considered redundancy for OS but unfortunately this setting had had before I knew about this decision, i.e. this equipment was configured not by me. And then when I attempt to open any file it doesn't open properly, it doesn't even open at all. I opened this files by DMDE, and discovered files filled up nulls. However, files which less 50-60 kilobyte open properly. Suggest any idea, please. Sorry for my English. Thanks a lot!
File comment: This is quite large file. Can't open.
File comment: This is the small file. It opens properly.
 Post subject: Re: Corrupt files NTFS
PostPosted: October 30th, 2020, 19:42
I don't know a lot about storage spaces, but the file from the 2nd screenshot is a resident file. As long as you find the MFT entry for it, you'll be able to recover it as it's stored inside the MFT entry - even if you managed to detect the MFT entry from a broken RAID.
For the rest I personally have some trouble following your story.
PostPosted: October 31st, 2020, 10:15
First of all, clone the healthy drive and work with the clone.
http://www.rescue-it.se
PostPosted: November 2nd, 2020, 7:17
mr_spokk, I've already made a copy of disk. Thanks!
Arch, thanks! I have only two disks which consist of RAID1 Storage Spaces. I've noticed that files which have "s" (NTFS Sparse Files) attributes don't open and these files consist of nulls. When I opened the MFT file I found some information. This information seems right excluding both #3($DATA) and #4($Other Attribute). Files without "s" attribute open properly and have a valid structure, but files with "s" attribute consist of nulls and have the different MFT record. Could you suggest any idea? Thanks a lot!
File comment: Extended MFT record #3 of the file without attributes.
File comment: Extended MFT record of the file with an "s" attribute.
File comment: MFT record with an "s" attribute.
Users browsing this forum: No registered users and 313 guests
