PC won't start due short circuit
June 2nd, 2009, 15:46
Hello.
I'm having a problem where my PC won't start if I plug in a SATA hard drive's power wire. With out it everything works fine.
When I turn PC on the lights blink for 1 second, but then just shuts down.
Tried connecting the hard drive to another computer(with different wires and connectors) and got exactly the same result.
I understand that the hard drive power connector is damaged, but is there any way I can get the data of it? The connector on the hard drive it self looks perfectly fine.
Thanks!
Re: PC won't start due short circuit
June 2nd, 2009, 15:59
Very common problem. If you search for TVS on this forum you will find more information.
Data recovery pros make a lot of money from this problem, which any amateur can solve with
a little care and for FREE !!
June 3rd, 2009, 17:01
Hi ,
Please replace the PCB after checking the same Model No and Firmwae from donor drive and you can get the data back .
June 3rd, 2009, 17:42
withyou wrote:Hi ,
Disagree!
We don't know the model/brand at this tiopic.
Replacing the pcb can be dangerous for the data!
Plese don't suggest anything when you don't know what you are saying!
results-the-yourself-solutions-t11912.html
Janos
June 3rd, 2009, 18:00
Hi ,
I already say to please select the same model no /firmware /model no...to replace the pcb and thats the first step.
to check the faulty hard drive...and take this process to check the hard drive having this type of problem.thats the very simple problem and we have to help.
N.C. wrote:
withyou wrote:Hi ,
Disagree!
Janos
June 4th, 2009, 3:36
withyou wrote:Hi ,
N.C. wrote:
withyou wrote:Hi ,
Disagree!
Janos
Still disagree!
The most of the pcbs have calibration / adaptive data inside.
Without these matching, with only matching stickers, the simple user easily can ruin hes data!!!
So, the suggestion is bad without known exact model.
Janos
June 4th, 2009, 4:12
Hi Withyou,
I think Gustavs will be better off withoutyou.
As N.C. wrote your advice has a small chance (Some 7200.7)
of being correct.
Gustavs did you find out info on TVS ?
June 4th, 2009, 12:55
derp wrote:Hi Withyou,
of being correct.
Hi friend,
But as you say the chance are there so let the user try.
or give some good suggestions :D
Thats my suggestions as per my experience.
June 4th, 2009, 14:36
withyou wrote:Hi friend,
Yes, there is a really small chance, but there is much more chance to ruin or corrupt hes data with another pcb.
I have seen a lot of times on seagate, it works with another pcb, but the data structure was different, and the scandisk was the real killer, because the user don't know about the different structure....
So, for protecting the users, the best suggestion is "ask only" and "don't do" alone...
In seagate, this is not a good idea.
period. :mrgreen:
Janos
June 4th, 2009, 14:54
"As per my experience".
I think, this dude keeps mumbling these words even while sleeping too.
This time I really remember, what Janos said in one of his post, it's modified version could be:
This world would be more secure "WITHOUT" you. :mrgreen:
June 4th, 2009, 15:07
:mrgreen:
June 4th, 2009, 15:18
Hi Hard Disk Bug ,
Better you have to give some suggestions with your own best of your knowledge as some body ask you or they want to help.as we are here to distribute our knowledge
and regarding hard drive either that is Manufactured by Seagate /WD /Maxtor /Westorn Digital/Fujitsu or many more
If problem is having from pcb and you replace the pcb with exact part no and firmware at seagate (if that is not dropped )you can find the data back at upto 90 %cases as i just share my experience or if you are having any suggestions please give the suggestions to rectify the problem..or we will mislead the user at this forum????.
Please give more suggestion as we want you for more fruitful answers if you think.
As criticism is better but mislead is not a good thing at healthier way.
and absolutily thats the first step for not detecting hdd and after that we will check the firmware and next to open the hdd ...
If you are having any other process than please suggest.
June 4th, 2009, 16:43
withyou wrote:...as we are here to distribute our knowledge
My God.... :mrgreen:
withyou wrote:If problem is having from pcb and you replace the pcb with exact part no and firmware at seagate (if that is not dropped )you can find the data back at upto 90 %cases
Based on 1 time experience? :D
withyou wrote:as i just share my experience or if you are having any suggestions please give the suggestions to rectify the problem..or we will mislead the user at this forum????.
Like a man with the axe in the forest... :?
withyou wrote:If you are having any other process than please suggest.
The most important is the diagnose.
First you need to measure the pcb without power, measure the preamp and everthing is good, measure the pcb alone with power, and if everithing is still good the next step can be the first start....
If no luck, you can check the pcb correct matching, and the connection to the HDA.
If still good, than the SA, and heads and servos, and so on.....
Janos
June 4th, 2009, 16:55
I have a dejavu feeling... Maybe Master Dmitry can check...
June 5th, 2009, 4:10
Withoutyou,
Just like real world, there are a few un-written, un-spoken rules about the forums. Being helpful is a nice thing, but there are some other things too. I suggest you to read some previous posts before your joining. Or, you can PM me or live chat me via messenger. After that, we would love to be WITHyou, not WITHOUTyou.
June 7th, 2009, 18:21
Hi Bug and Black,
Sorry to share my experience with this data recovery world ,as i think thats the open forum and we dont have to share our experience as at this forum we know there is some black and some bugs including no ,yes i know you are the experieced person and having so much post of this forum as you are very much expierience to send some numerious post as i read before that.
As today i saw the post and want to give some answers i.e Clean Room (as i am having my own clean room and want to share and distribute the drawings with this data recovery world ) and want to share and answer some more questions as i am working with this field from more than 15 years as from the hard drive of st 225 /251/351..
But i coudnt understand (you can PM me or live chat me via messenger)..
Either i have to talk first with you as if to post any answer at this forum but i didnt understand the word PM ,also please send your via messenger as you write and after that i can talk with you ..
Always withyou and with this forum
June 7th, 2009, 19:37
Withyou,
We never said, that sharing is bad or a "not to be done" kind of thing. But as I said, there are a few basic moral rules, which one should never forget.
As, you said, that what was your planning to "Share" it out, which makes it more freaky (about clean room and all that..whoa...)
Rest, you are wise yourself (I atleast hope so).
PM means Private Messaging, which is done between members to really "Share" and talk. It's a feature of forum, and you can find it in your user control panel.
