 Post subject: WD7500AAKS - ABRT errors on all sectors
PostPosted: June 11th, 2009, 1:02
I have a Western Digital WD7500AAKS drive that has failed. The drive spins up fine and initializes, and MHDD can see the drive properly, and gets proper ID and EID information. When testing the drive, all sectors return ABRT. I have verified the ATA password is not set.
Any suggestions?
 Post subject: Re: WD7500AAKS - ABRT errors on all sectors
PostPosted: June 11th, 2009, 1:08
Yes. SA.
PostPosted: June 11th, 2009, 2:39
Common problem on these drives; till now no good solution found yet.
Still researching it.
Dobre
Murphy was an optimist
PostPosted: June 11th, 2009, 9:27
Swap the PCB.
http://www.datasaversllc.com
PostPosted: June 11th, 2009, 9:37
Thats a possibility, yes.
Dobre
PostPosted: June 11th, 2009, 9:58
We've been getting a lot of Western Digital drives like this lately. Even though they are recoverable, they can be really tough and time consuming. I'm thinking that we're going to have to quote higher for these drives, knowing that they will require a lot elbow grease.
PostPosted: June 11th, 2009, 10:59
BlackST wrote:
Yes. SA.
Most likely not
TXRanger, this is tough case if you wouldn't be able to fix it by yourself - you can send it to us
PostPosted: June 11th, 2009, 17:09
@Doomer... from the symptom I suspected the SA, had some similar case, same symptom, the problem was SA related and not so easy to fix but anyway managed to fix and get 100% data (and still wondering why it happened...) , someone else suggested PCB (maybe ROM related then or something similar ?) , other have other ideas... well, without analyzing the drive it would be impossible to tell. It was my 2 cents, anyway.
PostPosted: June 11th, 2009, 17:18
Could very well be the PCB, had quite a few where a new PCB and subsequent ROM rebuild from the SA has worked.
PostPosted: June 11th, 2009, 18:25
-deleted-
PostPosted: June 11th, 2009, 18:27
Most of the WD Royal we see have contact corrosion and a MPU problem that is resolved by swapping the PCB. Symptoms look like bad SA, but it's not . . .
PostPosted: June 12th, 2009, 22:17
You can check translate module good or bad?
* Có ba thứ ngu dốt :
Không hiểu biết những gì mình đáng biết.
Hiểu biết không rành những gì mình biết.
Hiểu biết những gì mình không cần biết.
PostPosted: June 12th, 2009, 22:38
I bet he cannot read SA
PostPosted: June 12th, 2009, 22:48
Oh boy!
So, he can not deal with that HDD.
PostPosted: June 13th, 2009, 2:17
If you can read SA and it looks fine but no access to user data/any sectors - heads issue, if cannot then a lot of issues.
PostPosted: June 13th, 2009, 21:31
Secrets revealed :)
Users browsing this forum: Google [Bot] and 96 guests
