 Post subject: dead Maxtor DiamondMax 21 320GB SATA
PostPosted: June 14th, 2009, 22:55
I broke off 2 resistors pulling this hard drive out of the computer tower, so i think i will need a new PCB? here are the details:
STTM3320620AS
S/N: 6QF15BBY
P/N: 9DP14G-326
Firmware: 3.AAE
Data Code: 07494
Site Code: SU
can anyone help?
 Post subject: Re: dead Maxtor DiamondMax 21 320GB SATA
PostPosted: June 14th, 2009, 23:02
Just replace the resistors.
http://www.datasaversllc.com
PostPosted: June 15th, 2009, 1:22
i'm not a soldering guru, where do i get such resistors, and how hard would they be to replace?
any help would be appreciated. i still have the 2 i tore off, can i re-use them?
PostPosted: June 15th, 2009, 1:55
Check the two resistors with an ohmmeter for continuity and correct value (e.g. 221 = 220 ohms). If the solder pads are intact on both ends of the resistors, it should be a simple matter to reattach them using a little liquid flux, 63/37 solder, and a proper soldering iron. If you can't do this yourself, go to an electronics repair shop or data recovery firm. Unless something else is messed up, it is no big deal . . .
PostPosted: June 15th, 2009, 1:57
No . Ask a local skilled technician , they should be able to deal with SMD components.
PostPosted: June 15th, 2009, 9:49
My brother has a soldering iron, but i'm leaning towards going w/ a local skilled technician. looking in the yellow pages, i'm looking under "computer technician", is there a more technical term? i couldn't find any "electronics technician" listings on yellowpages.com
PostPosted: June 15th, 2009, 9:53
Normally any local shop that sells electronic components should be able to do it.
Dobre
Murphy was an optimist
PostPosted: June 15th, 2009, 10:26
Dobre
In the USA, many places that sell components do no in-house service (e.g. Radio Shack).
I suggest a TV or video repair shop, if they still exist . . .
Users browsing this forum: No registered users and 211 guests
