 Post subject: Maxto n40p issues
PostPosted: June 15th, 2009, 20:26
hi all
i have a n40p drive 40Gb 6E040l0510653 drive would show "safe mode detected" ad wold show firmware nar6159Z and no serial number.
i started the drive from a loader and proceeded to work with the drive.
now it shows me the correct serial number(mastches what is on the lid) identifies the model number an firmware correctly.
i do a SA test and get the below results.
it points out to module 18 being faulty adadvses to clear lists and regenerate translator
however the issue shappens when try to regenerate the translator i get the error below
Translator regeneration
P-List reading.......................... : Ok
SA P-List reading....................... : Ok
P-List file saving...................... : Ok
SA P-List file saving................... : Ok
Techno receive error Techno cmd error. Cmd : 59. Code : 0119
any ideas on how to proceed will be greatl appreciated.
than you in advance
this is the sa test report
Read roadmap............................ : Ok
Read roadmap extension.................. : Ok
Read zone allocation table.............. : Ok
Read Technological ID................... : Ok
Read Zone allocation table extension.... : Ok
SA head................................. : 3
Ext Model............................... : 6E040L0510653C
HDD has an alternate service area
HDD structures have been read successfully
Module : FF Copy0....................... : Ok
Module : FF Copy1....................... : Ok
Module : 37 Copy0....................... : Ok
Module : 37 Copy1....................... : Ok
Module : 1F Copy0....................... : Ok
Module : 1F Copy1....................... : Ok
Module : 78 Copy0....................... : Ok
Module : 78 Copy1....................... : Ok
UBA 164 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 352/3/164
UBA 165 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 352/3/165
UBA 166 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 352/3/166
UBA 167 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 352/3/167
UBA 168 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 352/3/168
UBA 169 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 352/3/169
UBA 170 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 352/3/170
UBA 171 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 352/3/171
UBA 172 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 352/3/172
UBA 173 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 352/3/173
UBA 174 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 352/3/174
UBA 175 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 352/3/175
UBA 176 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 352/3/176
UBA 177 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 352/3/177
UBA 178 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 352/3/178
UBA 179 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 352/3/179
UBA 180 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 352/3/180
UBA 181 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 352/3/181
UBA 182 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 352/3/182
UBA 183 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 352/3/183
UBA 184 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 352/3/184
UBA 185 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 352/3/185
UBA 186 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 352/3/186
UBA 187 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 352/3/187
UBA 188 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 352/3/188
UBA 189 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 352/3/189
UBA 190 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 352/3/190
Module : 18 Copy0....................... : Error
UBA 18786 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 386/3/426
UBA 18787 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 386/3/427
UBA 18788 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 386/3/428
UBA 18789 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 386/3/429
UBA 18790 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 386/3/430
UBA 18791 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 386/3/431
UBA 18792 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 386/3/432
UBA 18793 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 386/3/433
UBA 18794 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 386/3/434
UBA 18795 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 386/3/435
UBA 18796 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 386/3/436
UBA 18797 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 386/3/437
UBA 18798 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 386/3/438
UBA 18799 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 386/3/439
UBA 18800 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 386/3/440
UBA 18801 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 386/3/441
UBA 18802 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 386/3/442
UBA 18803 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 386/3/443
UBA 18804 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 386/3/444
UBA 18805 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 386/3/445
UBA 18806 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 386/3/446
UBA 18807 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 386/3/447
UBA 18808 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 386/3/448
UBA 18809 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 386/3/449
UBA 18810 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 386/3/450
UBA 18811 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 386/3/451
UBA 18812 (1) reading error. Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 386/3/452
Module : 18 Copy1....................... : Error
Module : 21 Copy0....................... : Header
Module : 21 Copy1....................... : Header
Module : 1E Copy0....................... : Ok
Module : 1E Copy1....................... : Ok
Module : 1A Copy0....................... : Ok
Module : 1A Copy1....................... : Ok
Module : 2F Copy0....................... : Ok
Module : 2F Copy1....................... : Ok
Module : 30 Copy0....................... : Ok
Module : 30 Copy1....................... : Ok
Module : 63 Copy0....................... : Ok
Module : 63 Copy1....................... : Ok
Module : 22 Copy0....................... : Ok
Module : 22 Copy1....................... : Ok
Module : 34 Copy0....................... : Ok
Module : 34 Copy1....................... : Ok
Module : 48 Copy0....................... : Ok
Module : 48 Copy1....................... : Ok
Module : 1D Copy0....................... : Ok
Module : 1D Copy1....................... : Ok
Module : 1B Copy0....................... : Ok
Module : 1B Copy1....................... : Ok
Module : 64 Copy0....................... : Ok
Module : 64 Copy1....................... : Ok
Module : 5E Copy0....................... : Ok
Module : 5E Copy1....................... : Header
Module : 70 Copy0....................... : Ok
Module : 70 Copy1....................... : Ok
Module : 71 Copy0....................... : Ok
Module : 71 Copy1....................... : Ok
Module : 72 Copy0....................... : Ok
Module : 72 Copy1....................... : Ok
Module : 7B Copy0....................... : Ok
Module : 7B Copy1....................... : Ok
Module : 95 Copy0....................... : Header
Module : 95 Copy1....................... : Header
Module : 39 Copy0....................... : Ok
Module : 39 Copy1....................... : Ok
Header1................................. : MO
Header2................................. : 5000
OverlayId............................... : 0003
ROM CRC................................. : Ok
CheckSum................................ : Ok
OverlayId............................... : 0004
OverlayId............................... : 0005
OverlayId............................... : 0006
OverlayId............................... : 0007
Module : 38 Copy0....................... : Ok
Module : 38 Copy1....................... : Ok
Header2................................. : 50m.
OverlayId............................... : 0008
OverlayId............................... : 0009
OverlayId............................... : 000A
OverlayId............................... : 000B
OverlayId............................... : 000C
OverlayId............................... : 000D
OverlayId............................... : 000E
OverlayId............................... : 000F
OverlayId............................... : 0010
OverlayId............................... : 0011
OverlayId............................... : 0012
OverlayId............................... : 0013
OverlayId............................... : 0014
OverlayId............................... : 0015
OverlayId............................... : 0016
OverlayId............................... : 0017
OverlayId............................... : 0018
OverlayId............................... : 0019
OverlayId............................... : 001A
OverlayId............................... : 001B
OverlayId............................... : 001C
OverlayId............................... : 001D
OverlayId............................... : 001E
OverlayId............................... : 001F
Module : 4F Copy0....................... : Ok
Module : 4F Copy1....................... : Ok
Module : 33............................. : Ok
SUMMARY
HDD modules necessary for start have reading errors. To eliminate them, check the SA surface with option "Correct BAD blocks by writing". Attention. After you do recovery, launch SA checking one more time because some modules can become unavailable for writing.
Modules | Comment
18 | Translator modules are defective. For restoration it should be
| performed:
| 1) To perform SA surface checking with the option of restoration BAD
| blocks via writing
| 2) To clear P and G-List
| 3) To restart HDD in normal mode
| 4) To perform translator regeneration
21,5E,95 | HDD has errors not critical for its normal operation. But before
| copying user data you should switch off automatic adding of defects to
| the defect-list.
 Post subject: Re: Maxto n40p issues
PostPosted: June 15th, 2009, 20:35
Copy the important module(s) to a donor and regenerate the translator. Then do hot swap.
http://www.datasaversllc.com
PostPosted: June 16th, 2009, 0:51
thank you for reply will try and advise later on progress.
PostPosted: June 16th, 2009, 3:32
relocate bad sectors in service area, write new p list, clear p list then regen translator. Or do hotswap method.
PostPosted: June 16th, 2009, 4:17
Not always works.
I have seen a lot of times, some drive can have head problem and can't write anything into the SA.
If you trying to relocate the defects, will ruin the U-list copys as well, and than game over, only the hotswap can help, if can at all....
So, the suggestion is good, copy the modules, regen the translator in another drive, disable the auto-reallocation, and than hotswap, and ONLY read, what you can.
This is the safe way. (until head crash)
Janos
PostPosted: June 16th, 2009, 6:57
hi guys
i rewrote all modules as required and that side of things went well, translator regeneration also worked well pc 3000 reported well on everything till i came to the last step of putting drive into standby and i got this error
sleep/standby error (ABR)
so i cant proceed any firther, any ideas ?
thank you
PostPosted: June 16th, 2009, 7:21
use something else to do the hotswap.
PostPosted: June 16th, 2009, 7:42
crecomp wrote:
hi guys
thank you
Aren't you in alt SA? 8)
PostPosted: June 16th, 2009, 8:13
No
Users browsing this forum: Google [Bot], michael chiklis and 274 guests
