Any hopes for my hard disk? Please help :(
June 19th, 2009, 2:49
hi, my samsung HD161HJ (sata) recently failed on me..
When I on my com it states "Windows could not start because the following file is missing or corrupt. C:\windows\system32\system".
First, i did a memtest on my pc to make sure its not my other harddware thats causing the problem.No prob was detected
I did a chkdsk /r /p, but it doesnt helped. I tried connecting the harddrive to my usb adapter to retreive all my data, but an error message popped up. So i thought, what the heck, just reformat it.
However I couldnt format my hard disk during re-installation of xp, it states that the hard disk might be damaged.
So i ran EStool(diagnostic tool from samsung), and it states no error.
I ran HDDregenarator, it states no bad sector..I did a low level formatting through the EStool and tried reinstalling XP, still the same prob appears again..
I tried running Darik's Boot And Nuke, and an error message appears, saying a non-fatal error had occured, and it might be caused by a bad sector.
I fixed the same harddisk again to another PC cause i thought it might be the mobo prob..but still the same error appears again...
what do i do now? should i get a new hard disk?
Re: Any hopes for my hard disk? Please help :(
June 19th, 2009, 2:56
If you don't have HW problem in your system the disk needs to be serviced. I can fix it 100% but I am the opposite corner of the world, so get another one if a pro near you (NOTE : A PRO, not a bedroom based computer nerd) is not available. It's a 10$ work.
June 19th, 2009, 4:54
Well, if u could share on how u'd repair the hdd i'd really appreciate..
June 19th, 2009, 8:01
I can't.
