 Post subject: WD4000KS-00MNB0 with H2 failed unable to clone
PostPosted: June 19th, 2009, 23:12
Hi guys
I have a WD4000KS-00MNB0 clicking continuosly, after H2 disabled the drive calibrated but failed to clone, all modules are ok including translator but cant access the data.
Anyone know the solution please PM me. thank you.
 Post subject: Re: WD4000KS-00MNB0 with H2 failed unable to clone
PostPosted: June 20th, 2009, 9:24
did you make it ?
ZeBong
" Россия еще раз"
PostPosted: June 20th, 2009, 9:36
I know the solution, but you need to replace the MHA and do the alignment for get the data.
I can help if you are not able to do that.
Janos
PostPosted: July 5th, 2009, 12:01
Janos
I have almost the same problem can you tell me how I can do the alignment ?
Thanks.
PostPosted: July 23rd, 2009, 18:59
If u want to align it U need precise tooling. It will cost u some $$$$ not to mention the knowledge..
Also we can help you with that problem, if interested.
PostPosted: July 23rd, 2009, 19:07
Interesting
will talk in PM
ZeBong
" Россия еще раз"
PostPosted: July 23rd, 2009, 21:55
I think Ace has a solution for cloning around a bad head in their next release. Check their forum to be sure.
I'd be inclined to do that first and then do the MHA swap if I could.
http://www.datasaversllc.com
Users browsing this forum: No registered users and 112 guests
