compatible smooth?
June 29th, 2009, 19:20
i have a wd120BES with a burnt smooth L6284*2.2 990cr vp mys 99 633
i found close enough drive but the smooth is L6284*2.2 992uw vp mys 9 642
can i swap and pray it works?
if i swap it do ihave to alter anything in the firmware?
Re: compatible smooth?
June 29th, 2009, 20:30
That should be compatible to my knowledge.
June 29th, 2009, 21:46
Could be but sometimes damaged to the spindle controller damage the MHA too
June 29th, 2009, 22:03
It is 100% compatible chip.
June 29th, 2009, 22:29
Swap the SMOOTH (L6284*2.2) shoule work.
Not need to match 990cr vp mys 99 633 or 992uw vp mys 9 642
June 30th, 2009, 2:41
thanks for the replies will let u know how it went
