 Post subject: I can't enable SMART on Maxtor 6B120P0
PostPosted: July 10th, 2009, 5:51
1rst I 'm sorry for my bad english. :oops:
I'm try to enable SMART on the maxtor 6B120P0 (Note that I use a 80"pin " IDE cable).
I try with smartmontools (win32)
smartctl -s on -T permissive /dev/hda
gives me this msg:
smartctl version 5.37 [i686-mingw32-xp-sp3] Copyright (C) 2002-6 Bruce Allen
Home page is http://smartmontools.sourceforge.net/
=== START OF ENABLE/DISABLE COMMANDS SECTION ===
Error SMART Enable failed: Input/output error
Smartctl: SMART Enable Failed.
SMART Disabled. Use option -s with argument 'on' to enable it.
and here is the result of smartctl -a /dev/hda:
=== START OF INFORMATION SECTION ===
Model Family:     Maxtor DiamondMax 10 family (ATA/133 and SATA/150)
Device Model:     Maxtor 6B120P0
Serial Number:    B415PEPH
Firmware Version: BAH41BM0
User Capacity:    122 942 324 736 bytes
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   7
ATA Standard is:  ATA/ATAPI-7 T13 1532D revision 0
Local Time is:    Fri Jul 10 11:43:25 2009 RDT
SMART support is: Available - device has SMART capability.
                  Disabled status cached by OS, trying SMART RETURN STATUS cmd.
SMART support is: Disabled
and here is for the 2nd maxtor hard disk:
Model Family:     Maxtor DiamondMax 4320 Ultra ATA family
Device Model:     Maxtor 90432D2
Serial Number:    A20KDBHC
Firmware Version: GAS54112
User Capacity:    4 321 787 904 bytes
ATA Version is:   4
ATA Standard is:  ATA/ATAPI-4 T13 1153D revision 17
Local Time is:    Fri Jul 10 11:44:34 2009 RDT
                  Enabled status cached by OS, trying SMART RETURN STATUS cmd.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: FAILED!
Drive failure expected in less than 24 hours. SAVE ALL DATA.
See vendor-specific Attribute list for failed Attributes.
General SMART Values:
Offline data collection status:  (0x03)   Offline data collection activity
               is in progress.
               Auto Offline Data Collection: Disabled.
Total time to complete Offline
data collection:        (   0) seconds.
capabilities:           (0x0f) SMART execute Offline immediate.
               Auto Offline data collection on/off support.
               Abort Offline collection upon new
               command.
               Offline surface scan supported.
               No Self-test supported.
               No Conveyance Self-test supported.
               No Selective Self-test supported.
SMART capabilities:            (0x0003)   Saves SMART data before entering
               power-saving mode.
               Supports SMART auto save timer.
Error logging capability:        (0x00)   Error logging NOT supported.
               No General Purpose Logging support.
SMART Attributes Data Structure revision number: 6
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000b   253   152   000    Pre-fail  Always       -       4295388370
  3 Spin_Up_Time            0x0027   234   218   063    Pre-fail  Always       -       59
  4 Start_Stop_Count        0x0032   252   252   000    Old_age   Always       -       3461
  5 Reallocated_Sector_Ct   0x0033   047   047   063    Pre-fail  Always   FAILING_NOW 519
  6 Read_Channel_Margin     0x0001   249   249   100    Pre-fail  Offline      -       4
  7 Seek_Error_Rate         0x000a   253   252   000    Old_age   Always       -       86302
  8 Seek_Time_Performance   0x0027   249   242   187    Pre-fail  Always       -       169870252171420
  9 Power_On_Minutes        0x0032   238   238   000    Old_age   Always       -       5354h+42m
10 Spin_Retry_Count        0x002b   253   247   223    Pre-fail  Always       -       95
11 Calibration_Retry_Count 0x002b   253   251   223    Pre-fail  Always       -       77
12 Power_Cycle_Count       0x0032   244   244   000    Old_age   Always       -       3733
199 UDMA_CRC_Error_Count    0x0008   199   200   000    Old_age   Offline      -       62
200 Multi_Zone_Error_Rate   0x000a   253   252   000    Old_age   Always       -       374510
201 Soft_Read_Error_Rate    0x000a   253   192   000    Old_age   Always       -       12885322962
202 TA_Increase_Count       0x000a   253   121   000    Old_age   Always       -       421074
203 Run_Out_Cancel          0x000a   253   113   000    Old_age   Always       -       421074
204 Shock_Count_Write_Opern 0x000a   253   249   000    Old_age   Always       -       421074
205 Shock_Rate_Write_Opern  0x000a   253   252   000    Old_age   Always       -       421074
206 Flying_Height           0x0026   239   237   000    Old_age   Always       -       13434657701942
207 Spin_High_Current       0x002a   253   247   000    Old_age   Always       -       95
208 Spin_Buzz               0x002a   253   252   000    Old_age   Always       -       95
209 Offline_Seek_Performnce 0x0024   253   253   000    Old_age   Offline      -       0
Warning: device does not support Error Logging
Error SMART Error Log Read failed: Input/output error
Smartctl: SMART Error Log Read Failed
Warning: device does not support Self Test Logging
Error SMART Error Self-Test Log Read failed: Input/output error
Smartctl: SMART Self Test Log Read Failed
Device does not support Selective Self Tests/Logging
I've send alot of request to Maxtor (seagate) support service but I got only NO Thing :evil:
Thank's for your support
Best Regards
PS: my PC is running Linux 2.6 and wind'oz
 Post subject: Re: I can't enable SMART on Maxtor 6B120P0
PostPosted: July 10th, 2009, 11:33
You have many bad sectors.
If you need your data refer to a recovery professional.
If yoou don't need your data, you have to "fix your bad sectors and after you would be able to take care of the SMART.
www.datarecoveryne.com
PostPosted: July 10th, 2009, 12:01
The drive has problems. Backup data and get new. I can fix it.
PostPosted: July 13th, 2009, 2:41
think's to all for your answer
I have no lost data. I always make a data backup.
By the past I've made on my 6B120P0 HDisk a "full format" (factory format) using seagate tools but this didin't fixe the probleme.
@BlackST, would you please explain how to fixe the 6B120P0 issue?
Best Regards
PS: sorry, as you can see, my english isn't good.
PostPosted: July 13th, 2009, 3:09
Hi, arabeman14,
This drive is allready too old to use more...
Additionally, have some bad sectors in the system area (SA), this is why you can't enable the smart.
I suggest, copy the data out and get a new drive....
BlackST have right, only selfscan can fix your problem, or an expensive hw/sw kit like PC3000.
Janos
PostPosted: July 13th, 2009, 4:05
You have to send it to me...
PostPosted: July 13th, 2009, 13:41
:D Thank's to all :D
I'll replace my current Maxtor device by another one (not Maxtor nor seagate :evil: )
Best Regards,
Arabeman
Users browsing this forum: Google [Bot] and 491 guests
