 Post subject: WD HEAD REPLACEMENT
PostPosted: July 16th, 2009, 4:37
I HAVE WD HDD 80GB WITH SOUND CLICK.
HDD INFORMATION
WD800BB-00JKC0 BACK-I
DCM :HSBHCTJAH
Made in Malaysia
COULD YOU PLS TELL ME THE HDD WD RULES FOR HEAD REPLACEMNT ?
Or What is the donor should much to replace the head ?
I HAVE 5 DIFFERENT MODELS 80GB WD BLACK I
1- WD800BB-00JHCO
DCM:ESBHNTJCH Made : Malaysia
2- WD800BB-00JHCO
DCM: ESBHCTJCH Made :Thailand
3- WD800BB-55JKA0
DCM: HSBHNTJCH Made :Thailand
4- WD800BB-22FA0
DCM:HSBHCTJCH Made :Thailand
 Post subject: Re: WD HEAD REPLACEMENT
PostPosted: July 16th, 2009, 4:55
You are far from the solution at this point.
You need to do the alignment after select and get the perfect match for donor.
Janos
PostPosted: July 16th, 2009, 9:33
Are you even sure that it's the heads? How did you diagnose?
http://www.datasaversllc.com
PostPosted: July 16th, 2009, 10:48
Banned User
is your pcb rom informations readable?
try to clean contact on pcb if not swap pcb first.
banned user
PostPosted: July 16th, 2009, 10:54
The most common problems at WD, Bad Sectors, PCB, MHA, SA some times FDB, like jono told u, are u sure its head problem, the knocking its contruisly, or knock 2 times and knock again, then motor stop, knocks 3 times and spindle stop what are getting on ATA registers? does hdd never reach readiness at any time?
 Post subject: 7 clicks
PostPosted: July 16th, 2009, 13:26
Hi Beto
The 7 knocks are continiusly and THEN STOP .The bios configuration is :WDC ROM MODEL--SHABRE-
so what is your advice.
Thank u
PostPosted: July 16th, 2009, 13:32
I think no servo.
1. pcb or contacts
2. preamp
3. head
But similar can be SA problem as well, but on this case the head can read the servo.
Janos
Users browsing this forum: No registered users and 94 guests
