 Post subject: Hello, I need some advice( and help if posible) from you
PostPosted: July 20th, 2009, 18:48
Hello all.
My name is Paul. I have a HDD HITACHI HTS5480M9AT00 , and the drive is locked. I do not know the user/master password. I'm asking you, if someone knows the password. I do not need the data from the hdd, I only want it to work.
Thank you very much in advance and I wish you all to have a great day.
Best regards,
Paul.
 Post subject: Re: Hello, I need some advice( and help if posible) from you
PostPosted: July 20th, 2009, 20:18
If you don't need the data, RMA it????
PostPosted: July 24th, 2009, 8:32
If PW is set and security level is highest, I usually work with firmware to reset PW or unlock. But it requires either HW tools or the knowledge to work with.
You can use online services that will unlock the drive AND erase it or unlock only.
