 Post subject: SAMSUNG HM160HI
PostPosted: July 28th, 2009, 9:14
Hi to all!! :mrgreen:
Please infos:
1) how to reach the FW of this model? It saw terminal? (PC3K PCI 2.21, 2.27)
2)OR using some tool free?
Hd is only busy and to reset it saw software is:
DRSC DRDY AMNF
when trying to recognize the model (F2 MHDD)
ERR WRFT DRDY ABRT
Thanks advanced!! :roll:
Нет ничего невозможного
 Post subject: Re: SAMSUNG HM160HI
PostPosted: July 28th, 2009, 14:08
What it show in terminal ?
PostPosted: July 31st, 2009, 9:47
Help? :?:
:idea:
PostPosted: July 31st, 2009, 12:06
Post the terminal log ... (what you see in terminal)
PostPosted: July 31st, 2009, 14:42
Sorry, After many attempts do not emit none log! :shock:
No clikclking.
spin off.
PostPosted: July 31st, 2009, 16:17
U mean it does not spin, and neither does output anything in terminal?
Probably the pcb is damaged, I would check TVSs and fuses first, then other supply voltages on the PCB.
PostPosted: August 1st, 2009, 5:57
Hi pepe!!
Hdd binds has rpm, makes some movements in the arms and after some seconds spin off.
Thanks!!
PostPosted: August 1st, 2009, 15:00
What's output on the terminal?
PostPosted: August 2nd, 2009, 11:28
Try giving it soft reset then try ID again .
PostPosted: August 2nd, 2009, 11:59
The terminal connector is the same as for Seagate SATA, except that Transmit and Reverse are swapped.
http://www.datasaversllc.com
Users browsing this forum: No registered users and 94 guests
