 Post subject: Seagate FreeAgent Desktop
PostPosted: July 26th, 2009, 0:40
Hello there fellow HDD's gurus.
I have a Freeagent desktop 500Gb, inside of it is a Seagate Barracuda 7200.11 500Gb(st3500620as).
The problem: when the drive is powered up, this sound begins and the PC won't detect the drive.
In your experience, you know what is going on here? how to fix it?
 Post subject: Re: Seagate FreeAgent Desktop
PostPosted: July 26th, 2009, 8:47
99% likely to be dropped/knocked and have stuck spindle.
And no, you can't fix it yourself. These particular drives with stuck spindle are very difficult even for pros.
PostPosted: July 26th, 2009, 13:02
It doesn't take much to get your spindle damaged... Dropp from a coffee table or even 2' would do or a little bump on the desk...
Spildit or Beto in this forum are pros and they are closer to you.
PostPosted: July 26th, 2009, 16:24
Beto is from Mexico.... :mrgreen:
PostPosted: July 26th, 2009, 17:07
But, if you value your data, don't open it at home or in your office!!! Take it to a clean room and don't touch the platters or heads with your finger!!!!
PostPosted: July 28th, 2009, 9:33
Like the another gurus told u its an spindle seized problems, another of typical problems on 7200.11 Families here on mexico we got most cases with spindle problems caused by dropped, than size 0 problem , where are u based on ?
PostPosted: July 28th, 2009, 22:09
Spildit wrote:
And i'm not a pro :oops:
@Caronte
Did you drop the drive or hit the drive ?
If heads are stuck on platters you have to find a way to "unstuck" them ...
Never hit or dropped this is the strange thing.
Hola beto, I'm from Venezuela.
Guys thank you so much for sharing your knowledge!
Users browsing this forum: No registered users and 234 guests
