 Post subject: BIG PROJECT 14 DISK FC
PostPosted: July 29th, 2009, 16:46
Hello to all hddgurus,
Anyone have worked in this kind off project.
Recovery this array ?
ZeBong
" Россия еще раз"
 Post subject: Re: BIG PROJECT 14 DISK FC
PostPosted: July 29th, 2009, 16:50
What's the array config?
PostPosted: July 29th, 2009, 16:51
I think is RAID 5.
ZeBong
" Россия еще раз"
PostPosted: July 29th, 2009, 16:57
zebong wrote:
I think is RAID 5.
how many damaged disks?
PostPosted: July 29th, 2009, 17:18
what type of drives?
PostPosted: July 29th, 2009, 17:37
I assumed FC=fibre channel?
PostPosted: July 29th, 2009, 17:52
I've learned not to assume .. I worked on a FC box
that contained Sata's.
PostPosted: July 29th, 2009, 18:10
The point is, connector doesn't really matter - config + damage effect recovery, connectors and size is only a matter of getting the right gear in...
PostPosted: July 29th, 2009, 18:50
connection might not matter, but geometry does.
Some, if not all, Fc drives have 520 bytes per sector,
While sata has 512.
Also some FC boxes that use Sata drives, write the full 520 byte
which throws off true sector count.. this doesn't matter to
the controller box, but it confuses the hell outta recovery
programs. then there's the OS overhead that is written
to some of the drives but not all depending on which system it is.
PostPosted: July 29th, 2009, 19:32
Again, I'd not consider that a major factor, I'd be more interested what the actual array fault was. One faulty disk is hardly a major issue with RAID-5, for example...
PostPosted: July 31st, 2009, 19:19
@zebong
if I were u, I would look at a good hdd and see how many partitions I can find on it, and that would at least give me an idea of where to start
PostPosted: July 31st, 2009, 19:29
Problem solved ;)
in to 2 disk.
ZeBong
" Россия еще раз"
