 Post subject: Seagate ST3500641AS 7200.9 clicking noise
PostPosted: August 4th, 2009, 10:21
Hi, i need an advice about my hard drive:
Seagate 7200.9
S/N: 3PM1FZ6A
ST3500641AS
P/N: 9BD148-304
Firmware: 3.AAJ
Datacode: 07084
Sitecode: AMK
I tried to mount this drive one day, my pc didn't power on.
So i tried in another pc and, omg, smoke!
So I read around forums by removing the burned protection diode the drive would be just ok to backup some data.
So I removed it, cleaned contacts and pcb and finally plugged again.
Result: no more "fireworks", but cycling (2sec more or less) "clicking" noise.
Do I need to find a new pcb (maybe controller fried?) or just mechanical parts dead?
What's your diagnosis?
 Post subject: Re: Seagate ST3500641AS 7200.9 clicking noise
PostPosted: August 4th, 2009, 11:34
There's something really wrong now. Maybe fried preamp INSIDE the drive HDA.
Need to diagnose it properly.
It was not a good idea to remove the TVS and leave the drive without any further protection.
If TVS have triggered, there should be a reason.
PostPosted: August 4th, 2009, 15:25
How do I diagnose that?
PS: The drive has broken because of damaged SATA molex that didn't fit 100% inside my seagate.
I think it caused a wrong alimentation or any voltage spikes that have burnt up the tvs.
PostPosted: August 4th, 2009, 15:42
Diagnose : by terminal then with PC3000.
THE PROBLEM IS NOT THE CAUSE BUT THE EFFECT.
PostPosted: August 4th, 2009, 16:56
How can I diagnose with pc3000? This is only enterprise stuff i think.
Is it probably simply the pcb controller f***ed up? Maybe weird voltages and stuff damaged the controller, not the mechanical parts such as heads.
Anyone have suggestions?
PostPosted: August 4th, 2009, 18:08
Yes it's enterprise stuff.
PostPosted: August 7th, 2009, 19:25
Probably preamp is dead.
which TVS was damaged? on the 5V or on the 12V line?
Users browsing this forum: Google [Bot] and 70 guests
