Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: SEAGATE: Non Standard ATA Master Password
PostPosted: October 13th, 2010, 4:29
Ray could not take even the 1st look... :lol:
PostPosted: October 13th, 2010, 18:18
dick wrote:
bubas wrote:
SeDiv 2008 , not support this hd :( :oops:
I would take a second look if I were you :shock: Roll on Ray :lol:
Take a third look. :roll:
PostPosted: October 13th, 2010, 22:06
HELLO PEOPLE! one more time ! sediv not support st3250312cs,and st3250310cs.
help pls , and can i use the cable rs232_to _ttl .or a a CA-42 cell phone cable ?? help pls, and the dku-5 , (noka) , can i use this work ?
tks
PostPosted: April 8th, 2012, 6:39
Hello, I also have 2 hdd Seagate ST3250312CS (old tv decoder). I make the cable RS232 (MAX232 thank you). In order to use these hdd, remove the password. I understand the principle:
Vendor to Track Seek, Read Track, Copy Bufer Read to Write Buffer, Edit Buffers to First Byte 00, wrote the buffer back to the drive.
With SeDiv, I can not find Track Vendor, the address buffers reads and write. :oops:
If a charitable person could help me, I would be grateful ...
Sorry for my English (thank you goooogle)
PostPosted: April 13th, 2012, 12:56
Up :oops:
can you help me for read the vendor track with sediv or not sediv?
PostPosted: May 9th, 2012, 6:03
I have se same problem with a 5400.6 (sediv support 5400.4..)
Any idea?
Bye!
PostPosted: May 20th, 2012, 5:39
how can I find the start address of vendor track ?
PostPosted: June 26th, 2012, 8:54
can you help me by PM if the response on the forum is indiscreet. Thank you in advance
PostPosted: June 29th, 2012, 8:12
how much this service cost me? thank you answer me by pm.
PostPosted: March 1st, 2013, 12:20
Hello, i've searched in every command reference, but couldnt find what mean the "G1" command used in the password unlock sequence? thx
PostPosted: March 1st, 2013, 15:44
In level T (Level 0 or main test level) Gx reads a sector from VENDOR data track, where x stands for sector number, so G1 is to read the sector 1 or VENDOR track.
PostPosted: March 1st, 2013, 15:47
ALSO NOTE THAT 7200.11 and newer drives, and SCSI are based on another type of firmware F3> and the commands of older drives are diferent from te ones used on newer ones !!!!!!!!
PostPosted: March 1st, 2013, 16:14
Spelling mistake :
so G1 is to read the sector 1 OF THE VENDOR track (not or)
PostPosted: March 1st, 2013, 19:59
Ok, ty Spildit. I had found the information in the meantime into the file called "seagate diagnostic command.doc"
I was trying to understand this sequence of command her:http://forum.javaxtreme.com/threads/103-Seagate-Diagnostic-Command-List?p=1958&viewfull=1#post1958
i think i got it for the main part.
I still wonder exactly why there is second argument (which is supposed to be the write buffer 40D)...
Im currently trying to download the different modules as explained into the this file, into T level:
uxx Upload CERT, RWF, CSPT, DEF from Serial Port to Buffer then write from resv
Performs the uploading of files from the reserve tracks. The keys are exact the same as those in the download command.
When trying to do that each time i got this response:
T>u1
Command Inactive - No VALID Cert Code Detected
Is this the command supposed to be used to get the different modules of the system area?
Sorry for the maybe noob questions, i'm alone as you are Spildit.
PostPosted: March 2nd, 2013, 11:23
To write the "edited" data back to disk.
Addr 0 1 2 3 4 5 6 7 8 9 A B C D E F 10 1 2 3 4 5 6 7 8 9 A B C D E F
081A00 01005365 61676174 65202020 20202020 20202020 20202020 20202020 20202020
In RED you have 01 (password locked) and you want to change it to 00 (without lock) so instead of figuring out the password you edit the address on memory
1>U81A00
Adr 81A00 = 01 --> 00 {Shift+Enter = Save and Edit byte again}
Adr 81A00 = 00 --> {Ctrl+Enter = Save and Edit Next byte}
Adr 81A01 = 00 --> {Enter = Finish}
From 01 to 00
And then you write it back from memory (buffer) to disk (platter).
T>u1
You have to load Cert code first !
CTRL+R on terminal will load CERT.
PostPosted: March 2nd, 2013, 11:26
You also have a read buffer and a write buffer, so you have to first copy from read buffer to write buffer, and only then write back to disk the edited data.
PostPosted: March 2nd, 2013, 12:34
1>U81A00
From 01 to 00
T>u1
Sorry but i mean why there is NO second argument in the line:
C3FD,,10
The second argument is supposed to be the destination, buffer, and the manual does not say what it do if you dont put it, by default it is the write buffer?
About the No VALID Cert Code detected, i've tried everything with no solution. CTRL+A CTRL+R and also /1 level and the "r" command. Nothing works.
See by yourself:
T>u10
T>Eng Rev = .0E1
TONKA2 - 1_Disk    3.ADH  02-08-06 16:13 ADH,1H_S_013_M1,4T
CERT Rev = .0B8
.0B8
Mask Rom Rev = M-31
Unique Descriptor = .3M1
T>/1
1>r
VALID Cert Disk Code Detected - Revision # .0B8
1>
1>/T
T>u10
The drive is a seagate 7200.9 ST3808110AS. Regards
PostPosted: March 2nd, 2013, 12:48
Uxx - Upload CERT, RWF, CSPT, DEF from Serial Port to Buffer then write from resvPerforms the uploading of files from the reserve tracks. The keys are exact the same as those in the download command.
Dxx - Download CERT, RWF, CSPT, DEF from Serial Port to Buffer then write to reserved cyl
.xx = - FILEKEY for downloading.
1H OVLY_CCT
2H OVLY_ACT
3H OVLY_XX
4H DEFRSV
5H DEFFTY
6H DEFUSR
7H DEFLZT
8H RWF
9H SYSVAR1
AH SYSVAR2
BH CSPT
CH VBPI
DH FLSH_AT
EH FLSH_CT
0FH AT_STUFF
10H SECURITY
11H VENDOR_SPEC
12H SMART ATTRIBUTE
13H SMART THRESHHOLD
14H SMART DIRECTORY
15H SMART ERROR LOG
16H SMART COMPREHENSIVE LOG
17H SMART SELF_TEST_LOG
18H SMART CRITICAL_EVENT_LOG
19H SMART HEALTH_LOG
1AH SMART DRIVE_VENDOR_LOG
1BH SMART HOST_SPECIFIC_LOG
1CH WRITE_PROTECT
1DH CON GEN
1EH SKIP CYLINDER LIST
= 8X – For DLE only, ie. Only downloaded to buffer Ram.
= 88 – DLE only for RWF.
= 8B – DLE only for CSPT
Level 2
Cxx,yy,zz - Copy Buffersxx = Source buffer for the data.yy = Destination buffer of the data.zz = number of 512 byte buffers to copy (1 is default)
PostPosted: March 2nd, 2013, 19:59
I had the manual thank you, did you read my last post? I just dont understand why the upload module from reserved area, does not work as seen in my example.
By the way, do you read your PM Spildit?
PostPosted: March 3rd, 2013, 11:24
Yeah, i don't know either :)
I will reply to your PM later today.
Users browsing this forum: Google [Bot] and 77 guests
cron
