 Post subject: Error creating hard drive label
PostPosted: August 10th, 2009, 14:55
Hello! Thanks to the help of this forum I have already recovered/re-purposed one drive however I'm having trouble with another.
I received a drive from an old DVR box and had planned on using it as a pc drive, I connected it to the pc (sata) and the pc didn't recognize it. I followed the steps found in this post by Spildit and booted a linux live cd which was able to recognize the drive.
how-flash-firmware-for-wd3200js-hard-drive-t9666.html
However when looking at the drive from ubuntu (I assume the disk analysis software was gparted) it shows the drive as being one big block of unallocated space. I then try to create a new partition and in doing so it tells me that it must setup a label for the disk, it goes through the process of creating the label but then fails saying unable to create disk label.
What options if any do I have?
Thanks!
 Post subject: Re: Error creating hard drive label
PostPosted: August 10th, 2009, 15:08
The data is definitely not important. I'll try mhdd and see what I can do with it.
PostPosted: August 10th, 2009, 15:46
mhdd shows no password on the drive (it shows security high, off).
PostPosted: August 10th, 2009, 17:01
When I try to erase the drive I get an error (can't write on drive):(
Users browsing this forum: Google [Bot] and 96 guests
