 Post subject: toshiba 2.5 inch notebook
PostPosted: August 6th, 2009, 23:39
Hi all
i have a drive that is a mk1034GSX 100gb with a clicking sound and wont become ready, i dont think the pc3000 fully supports this drive .
i have a donor drive that is a mk1032GSX 100Gb, same interfaces, same country of manufacture
does anyone know the difference between the 1032 and 1034gsx and whether parts are interchangable on this model
thank you
 Post subject: Re: toshiba 2.5 inch notebook
PostPosted: August 7th, 2009, 14:02
My guess is that if upon visual inspection of the heads they appear identical then you're probably safe in assuming they'll work.
PostPosted: August 7th, 2009, 14:17
agree
PostPosted: August 7th, 2009, 19:03
leave some feedback if u tried it, pls.
PostPosted: August 7th, 2009, 20:33
After head swap it still didn't work, issue was tracked down to a faulty board
I did a board swap from mk8034 drive from same family and the drive becomes ready but has wrong adapatives to it so will need yo move bga over to donor board
the mk1032 and mk1034 are different families
has anyone had good success with moving bga chips on these drives and can they share any thoughts on the process
thankyou
PostPosted: August 7th, 2009, 20:56
major pain in the ass. Unless you have the required equipment and skills, I suggest you outsource the BGA swap to an electronics specialist. Based on the relatively low number of such transplants that we need to do, we use a local specialist who has the correct setup, including x-rays which they send us to confirm the balling was successful.
Data Recovery Ireland
PostPosted: August 7th, 2009, 21:03
Thx for answer.
I have a high end infrared rework station but have not done a bga chip yet
other types with pins exposed not an issue. I have some spare boards to playwith for bga so may give them a go and see how it goes and if no luck then will look to outsource
thx for replied
PostPosted: August 10th, 2009, 3:18
i think disk head can do replacement! but PCB need to try ,need repalace ROM chip or DSP chip!
bettween 32 and 34 diferent in buffer !
Users browsing this forum: Pi0tR and 66 guests
