 Post subject: Is WD1600BEVT-75ZCT2 match for WD1600BEVS-22RST0
PostPosted: August 9th, 2009, 6:25
Hello Gurus,
Can you tell me please if WD1600BEVT-75ZCT2 match for WD1600BEVS-22RST0. Because I need PCB for WD1600BEVS-22RST0 and found only that replacement in the local market.
Also can anyone please please tell how to know the perfect match for your WD drives?
Thank you in advance,
Mob
 Post subject: Re: Is WD1600BEVT-75ZCT2 match for WD1600BEVS-22RST0
PostPosted: August 9th, 2009, 8:41
Dear Mob,
please let me know both model of your PCB which is brand on PCB. i would like to help. thanks.
data recovery service[/b]
PostPosted: August 9th, 2009, 10:07
1- The donor drive is :
WD1600BEVT-75ZCT2
DCM:HACTJBBB
PRODUCT OF THAILAND
2061- 701499-E00 AC XC 5H28 6VG1 7 0005520
2- Damaged hdd is :
WD1600VEVS-22RST0
DCM: HBCTJBBB
PRODUCT OF THAILAND
2061-701450- Z00 AB XT 3W19 LNJJ 2 0001320 7 321
I appreciate it thank you,
Mob
PostPosted: August 9th, 2009, 14:59
You need to match the PCB#, for the older WD drives, you may be able to match the 2 main chips on the PCB to make it work but I don't think these new ROYL ramilies will work like that...
Good Luck for your search!!!
PostPosted: August 9th, 2009, 17:16
Thank you guys I think you are right. In fact I tested it but it didn't work.
What do you think the problem is when you turn on the hdd and heare a very low electronic sound keeps sounding four or five times and then stops.
PostPosted: August 9th, 2009, 18:07
First you should diagnose the problem correctly. Secondly, a PCB swap even with identical is only the beginning...you need to create original ROM from modules OR move entire MCU from old PCB to new one (assuming PCB is really at fault). However, I have seen many of these drives with heads stuck to platters while unable to park correctly onto ramp. Probably this problem or motor is my guess. either way, this problem would likely be too difficult to solve by anyone who would not know this answer already...
http://pcrecoveryllc.com
PostPosted: August 10th, 2009, 1:22
Well thank you guys I got it.
Users browsing this forum: No registered users and 253 guests
