 Post subject: Seagate 750gb barracuda 7200.11 wont spin up
PostPosted: August 13th, 2009, 15:08
Seagate 750gb barracuda 7200.11 wont spin up. I don't know too much about hard drives so bear with me... but I believe it may be related to the circuit board.
Problem is... the drive was part of a RAID0 that held important files. And worse yet, the backup to the raid died two weeks ago. (7200.10) It has crucial data for my business. I do have some backed up on DVDs but not everything.
i365 quoted $2900 to recover the dead drive and recover the raid. I will triple back up from now on.
The other disk in the Raid is a 7200.11 as well... I switched circuit boards and the dead drive now does spin up then makes a few clicking sounds and spins down. With the original board the drive doesn't even try to spin up.
I searched the whole board for some fried area and everything looks pretty clean, below are photos of the only area that may be burnt out along with model and serial.
Is $2900 a crazy quote for this type of operation? I know the RAID0 makes everything alittle harder. Next time I will go with RAID 1 or 5 I didn't even notice too much of a real world improvement using the RAID0 over my velociraptor 300gb. Benchmarks yes.. real world performance... not quite.
thanks!
 Post subject: Re: Seagate 750gb barracuda 7200.11 wont spin up
PostPosted: August 13th, 2009, 16:37
Hi
The problem is probably pcb related, so U have to swap the PCB, but together with swapping the ROM chip as well.
The raid will make things a bit harder, but I suggest to make an image to a spare drive and put the drives (the working one and the image) back to their places, and see if the controller finds the array.
If yes, U are lucky, if not, U will have to recover the raid by SW.
If u are not familiar with doing such things, U will have to take it to a pro, but $2900 is a bit much I think.
There are some members here from the USA, u may get a quote, it will surely be much lower.
PostPosted: August 14th, 2009, 1:54
Peter, the problem may not only the PCB, but the shock probably fried preamp as well.
So apparently, reviving pcbs and heads of a 7200.10+7200.11+Raid system reconstruction=2900..yeah a bit high, but not as crazy as the author thinks it is.
I just hate spammers...It was a Spammer, who ruined my life!
PostPosted: August 14th, 2009, 9:52
yes, if preamp is fired, the amount is getting more reasonable.
However I would not dare to charge that amount.
Checking the preamp is a good idea.
Users browsing this forum: No registered users and 60 guests
