 Post subject: WD800JB-00FMA0 - Stays BSY always
PostPosted: August 17th, 2009, 13:42
Hi to all,
Have this disk that when i connect it it stays BSY always.
I put in Kernel mode and also the same happen.
i dont have any other PCB for change an try.
PCB 2061-001209-290 AE XC 1T08 0C1W 1 0001320 4321
Any advice will be great.
ZeBong
ZeBong
" Россия еще раз"
 Post subject: Re: WD800JB-00FMA0 - Stays BSY always
PostPosted: August 17th, 2009, 13:46
you can try
2060-001130-XXX
with this drive
PostPosted: August 17th, 2009, 14:25
thanks rameez,
i dont have that one.
so i test the other one that i have
2061-701292-000 AV
I could get DRD DSC, but not the correct size, need the ROM for the patient, but i notice that the marvel chip is different,
P - 88i5540-LFH - 2003 - Family - Mammoth
D - 88i6540-LFH1 - 2006 - Family - Sabre53
can i do something here ?
ZeBong
ZeBong
" Россия еще раз"
PostPosted: August 23rd, 2009, 5:35
no 1292 will not work you can also try 1252 its sata for 1209 .
PostPosted: August 24th, 2009, 18:44
i order this PCB 2061-001209
now i can have DRD DSC, but need to know if this drive as too much adaptive, or can i change write some ROM versions until i get the ID off the drive ?
ZeBong
ZeBong
" Россия еще раз"
PostPosted: August 24th, 2009, 23:24
check firmware first or do hot swap for check.
data recovery service[/b]
Users browsing this forum: No registered users and 137 guests
