 Post subject: help in hd - WDC ROM MODEL--SCORPIO - recover
PostPosted: August 26th, 2009, 13:37
the testdisk application show the half of capacity
and none partition
somebody help me?
Could someone show me some application for data recovery that can make a good read on WD drives.
I use testdisk, but it tells only half the capacity of HD.
not inform the partitions.
Is there any application pra fix this, or me to get access to some of the data.
 Post subject: Re: help in hd - WDC ROM MODEL--SCORPIO - recover
PostPosted: August 26th, 2009, 13:49
If you not faced with HPA or LBA32 bit limitation, then you have SA problem.
In this case you will need some special SW/HW complex to solve the problem, wich is much more expesive then paying for a local recovery service....
Janos
PostPosted: August 26th, 2009, 13:50
Oh, i forget:
You can check HPA with MHDD. ;)
Janos
PostPosted: August 26th, 2009, 13:52
If it's showing up as ROM MODEL whatever, then I think its too late for amateur help.
PostPosted: August 26th, 2009, 15:47
oh, yes, i have missed this part.
This is true.
The size what you see, is only fake if the drive ID have the alias only....
drccsc are right.
Janos
PostPosted: August 27th, 2009, 8:28
thanks for the personal attention
I like Czech HPA with MHDD?
you can show me utility for linux or windows.
how should I proceed?
what would you do in this situation? which would install and how to check?
PostPosted: August 27th, 2009, 8:38
sorry for my ignorance.
already got the MHDD
do not know how to use
is how I explain step by step the basics?
do not want to damage the disc. he works as a read-only?
especiifica in a case like mine that tells the disk capacity by half and testdisk not find partitions what can I do?
you think you have a solution?
PostPosted: August 27th, 2009, 8:53
the drive is in a mini case - USB
and not detected
I am using windows vista and the case is pluged
the testdisk detect! but the size is incorrect
PostPosted: August 27th, 2009, 9:10
I caught the usbaspi.sys
but the drive has a letter in windows
testdisk only detects the drive
Windows does not detect or give the drive letter
PostPosted: August 27th, 2009, 9:21
i am using HDDScan now...
PostPosted: August 27th, 2009, 10:31
the utility - disk manager of windows
identifies the disc but can not boot
gives error.
is there any way to resolve the startup disk by the Disk Manager or another utility.
some tools do not identify any partition
nor Partition Find and Mount found nothing.
I think the partition table is corrupted
I think if you can boot the disk. Windows itself can read.
PostPosted: August 27th, 2009, 14:56
Listen carefully :
Your drive is recognised as "SCORPIO" that is the factory alias. To cut a long story short : when the drive is experiencing SERIOUS problems it identifies himself not like WDCxxxxx and with correct capacity but with ROM MODEL yyyyy where yyyyy is the alias, in your case SCORPIO (2,5" family). NO SOFTWARE CAN ACCESS DATA IN THIS CONDITION AND CAN REVIVE YOUR DRIVE, NEED TO USE SPECIAL EQUIPMENT TO CORRECT THE PROBLEM AND ACCESS YOUR DATA.
Is this clear enough ?
Users browsing this forum: No registered users and 137 guests
