 Post subject: 2.5" ATA WD1600BEVE strange bad areas
PostPosted: September 4th, 2009, 5:52
I am new here, found this good forum about hdds after searching for MHDD.
My pata laptop hdd decided to start giving me headaches. :D
It`s a brand new Western Digital 160gb ATA hdd, manufactured January 2009. I bought it from a friend (has no warranty although it`s new, lost it) to put in in my old ata laptop.
Worked well until 5 days ago, when while browsing the web with firefox the hdd led started blinking fast and the system did not respond. After a restart, the system failed to boot (ubuntu 9.04). Tried restoring grub loader, rebuild partitions with gparted, nothing, the hdd led will blink continually.
After reading some post on this forum, I tried MHDD scan. It reported bad sectors in the first 5% sectors of the hdd (a lot of X and brown areas). Tried erasing the HDD but with no luck, it failed after a few sectors giving me a "broken disk" error. Tried running scan again, gave me errors again but it different sectors, still in the first part of the hdd.
I used hdd regenerator then (I know.. you don`t recomend it) and if said it fix some bad clusters, but the program just kept telling me it could not continue because IDE not ready.
In the end what I did was to make with a live cd a blank 8GB partition at the start of the hdd and install Ubuntu after.
The laptop works ok now, the hdd speed is good. Don`t get it, what happend? I did not hit the hdd, etc. After the first 8GB the hdd is good, should I use it like this? Every time I run MHDD I get different X count and brown areas.. strange, shouldn`t it be the same sectors every time?
And one thing, how can I clear the smart data, because ubuntu keeps telling me the hdd has a problem and it`s annyoing.
Thanks for your time!
 Post subject: Re: 2.5" ATA WD1600BEVE strange bad areas
PostPosted: September 5th, 2009, 19:47
Are you sure there is no warranty? Should have 3 years from date of manufacture.
Check here http://websupport.wdc.com/warranty/seri ... ty&lang=en
PostPosted: September 6th, 2009, 4:25
I have checked with the site you gave me and it says it has warranty until 2011. :D Now I will try to RMA-it, hope it works worldwide. :roll:
PostPosted: September 6th, 2009, 15:55
You are allowed one "out of region" drive per year anyway, so should be OK. :-)
PostPosted: September 6th, 2009, 16:29
It says it costs me 140 dollars shipping cost to Germany. Don`t know if they will return the amount back with a new drive, but it does not worth it. I will keep the drive like this, and hope my friend finds the warranty.
Users browsing this forum: Google [Bot] and 99 guests
