Western Digital SATA Drive wd1600AAJS
September 14th, 2009, 16:53
hello, i need some help
I have a western digital 160 GB hard drive (wd1600aajs) that after a power falure is no longer detectd in the system bios.
I have change the PCB with an identical drive, but still nothing ????
Re: Western Digital SATA Drive wd1600AAJS
September 14th, 2009, 17:33
This can be different problems.
Anyway, a simple pcb swap usually not solves problems, but makes more...
If you want your data, ask some pro near you for help.
If you want read, try this:
results-the-yourself-solutions-t11912.html
Janos
September 15th, 2009, 5:36
Specialist equipment is needed to maintain compatibility between the firmware on the HDD and the code in ROM of the PCB. Simply replacing PCB is useless. Professional help is needed.
