 Post subject: Barracuda ES.2 firmware issue
PostPosted: September 18th, 2009, 5:15
can anybody how to access terminal on LED CC blocked disk
it's different recovery by ES.2 than 7200.11?
CTRL-Z is not working on dismounted PCB
 Post subject: Re: Barracuda ES.2 firmware issue
PostPosted: September 18th, 2009, 5:42
short circuit read channel..
Data Recovery Ireland
PostPosted: September 18th, 2009, 5:57
It's on all Barracuda ES.2
we have 3x 250GB
PostPosted: September 18th, 2009, 6:27
shor circuit did not work for us
HddSurgery - Professional Data Recovery Tools
PostPosted: September 18th, 2009, 6:28
it worked for me on 1 drive, had one this week which took some extra work. Have not been able to do one with UDMA though..
PostPosted: September 18th, 2009, 7:19
Can you tell where to shortcut it ????
PostPosted: September 18th, 2009, 9:29
This is the same as a 7200.11. Same repair procedure for both. It's been exhaustively documented on this site.
PostPosted: September 20th, 2009, 7:19
Post picture of pcb we will mark the position of points .
PostPosted: September 20th, 2009, 8:27
very similliar
URL http://www.angelapan.com/samples/pcb.jpg
PostPosted: September 21st, 2009, 9:25
The Read channel needs to be shorted at the right moment, and PCB must NOT be detached. If successful the HDD may click several times then reach readiness and you can then proceed with repair.
mrsurgeon is right, it has been documented a lot in this forum, among other places also, you just simply need to find it.
Users browsing this forum: Google [Bot] and 65 guests
