 Post subject: [Help]hard disk problem
PostPosted: March 22nd, 2014, 13:44
hi,
i need some help about my hard disk problem,
i have a laptop with seagate sata drive 500G hard disk
a few days ago when i turn my laptop on the system says that i need to repair may operating system . when it try to do it there no respose from the hard disk so i decide to hard reset the laptop. and i took of the hard disk and i put it on an external hdd connector.
when it try to access it as external hdd on my computer, in cannot see it on my OS explorer.when i open device manager on my operating system may i can see my hdd but for some partition is not mark with drive letter and not mark as a healty partition
like this picture below
so i want to ask what i need to do about this problem? anyone can give me sollution??
i'm sorry about my english, i hope you understand what i mean
thank you
 Post subject: Re: [Help]hard disk problem
PostPosted: March 22nd, 2014, 14:27
Did you you try to add a letter ?
Or simply search for a recovery software like R-Studio or similar and retrieve your data.
good luck
PostPosted: March 22nd, 2014, 15:36
Whatever you do, the last partition is your recovery partition. If you don't have the recovery DVDs (even if you do, if you ask me, because DVDs become defective sometimes), you will need that partition to use the laptop.
Download Hiren's boot CD from somewhere (preferably version 9) and clone that partition to another drive, and write down its size somewhere (15.22 GB), so you can restore that partition to that or to another drive.
When you get another 500 gig drive, you can make a 480 gig partition, then a 20 gig partition, then clone the 15.22 gig partition back to the 20 gig partition, then use Ranish Partition manager or Acronis to set the boot flag on, on that partition. Then boot off the new HD and it will go into system restore, and restore to factory new.
http://www.youtube.com/user/TerraformingMaster
PostPosted: March 22nd, 2014, 15:48
If you can get another HD of the same or larger size (preferably the same model, or at least the same LBA) then use a disk to disk sector copy utility (someone here will name a good one), then you can try try to use testdisk or another disk recovery utility on Hiren's boot CD. But run a MHDD scan first, after you do the clone.
After you make the clone, it doesn't matter if you screw up the recovery attempt, because you can always disk-to-disk sector clone it back and try again.
PostPosted: March 22nd, 2014, 18:11
You can try Partition find and mount, mount the partition and copy the files you need, or better still take an image of the disk so you at least can retain your data.
and/or follow Feklars last post, do it first, as this would give you a safety net.
After you have your files you can replace the disk, or at least wipe all partitions and repartition, reformat and see if the disk has actual problems or it is purely logical(software/corrupt files/OS).
PostPosted: March 22nd, 2014, 20:46
i already try use recovery data software but when i connect the hdd that SW become not responding when searching hard drive.
but thanks for all your input i will try it.
Users browsing this forum: No registered users and 133 guests
