 Post subject: WD800 unicorn RAM reading error "VSCE PERM OVL NOT LOADED"
PostPosted: September 21st, 2009, 12:18
Hi everybody!
I have a problem with one hdd model: WD800JD - 75MSA1, maybe its have a head problem, but I'm not sure, the head and SA test is with errors, so I dont know what is exactly the problem, the heads or the SA. In the PC3000 is shown that report:
Head number reading..................... : Ok
Heads number............................ : 2
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 128 Kb
ROM version............................. : 10.8SE
ROM generation.......................... : 10.8SE
Link table version...................... : 02.88.
Heads number in use..................... : 2
Switched off heads...................... : No
Head map................................ : 0,1
Firmware version........................ : 108S?
Service area:
SA dir reading.......................... : Device error detected VSCE XFER REQ EXCEED AVAILABLE DATA
Configuration reading................... : Module 02 not found
So...somebody have the same problems with that HDD?
Users browsing this forum: No registered users and 69 guests
