 Post subject: Seagate (SD35) firmware update file brinks-3d6h-sd3b.iso
PostPosted: September 27th, 2009, 2:59
Hello Everyone,
I was able to recover my harddisk with following details from the BUSY (aka BSY) error by using the USB to TTL method of issuing serial ATA commands to the PCB. Its working fine now and have backed up all the data.
Seagate Barracuda 7200.11
Model: ST31000333AS
S/N : 6TE08QZ5
P/N: 9FZ136-568
Firmware: SD35
Date Code: 09204
Site Code: SU
PCB (printed on right corner of PCB) : 100512588 Rev A
However it still needs a firmware update which is not yet posted on the seagate website for drives with firmware SD35.
Can anyone provide me with the firmware file, you can upload it to any sharing host or can directly email me on hyper.escape@gmail.com. The file I am looking for is " brinks-3d6h-sd3b.iso ". I have already done it for my other drives so I know the procedure.
It would be a great help and I would be thankful
Regards.
 Post subject: Re: Seagate (SD35) firmware update file brinks-3d6h-sd3b.iso
PostPosted: September 27th, 2009, 4:26
It appears that Seagate will email you a copy if you start a support case with them.
http://forums.seagate.com/stx/board/mes ... e.id=12458
PostPosted: September 27th, 2009, 4:56
Thanks,
What appears to you is quite correct, they have been contacted too, but they would take quite sometime in sending me the link to download firmware. Since i wanted to be quick I was hoping that some good soul on the forum who has already done it would be kind enough to share this firmware file with me and make my life easier. :-)
Regards.
Users browsing this forum: No registered users and 149 guests
