 Post subject: WD 1500 ADFD died
PostPosted: October 7th, 2009, 10:06
Hi,my raptor died just in a second without any warning.Just blue screen and thats it.It is OONLR1,controller board is Rev A.I tried to change board from OONLR5 with same board revision but din't work.Bios doesn't find it,it warms up somewhat but no clicking sounds.Is there anything i can do?
 Post subject: Re: WD 1500 ADFD died
PostPosted: October 7th, 2009, 10:33
you may want to ask pro for help
Raptors of this model may stay quite even with damaged heads
Finland is very close to Saint-Petersburg, Russia
I suggest Q-Lab there - http://q-lab.ru/en/index.shtml
PostPosted: October 7th, 2009, 10:43
You think it's heads?Should i try to change them from other one i have?Is there difference between OONLR1 and OONLR5?
PostPosted: October 7th, 2009, 12:01
there is no difference between 00NLR1 and 00NLR5
If you feel like you want to change heads - change them
But I must warn you - this drive is not easy one if you never did Raptor with internal problems before I really not recommend to open it
PostPosted: October 7th, 2009, 13:16
Those internal magnets are really strong . . .
http://www.datasaversllc.com
PostPosted: October 7th, 2009, 13:26
Well,i replaced them but still same thing.Not recognized,clicking.What now?
PostPosted: October 7th, 2009, 13:27
prepare to pay double the money for data recovery :lol:
PostPosted: October 7th, 2009, 13:31
Nope,maybe changing platters to other body?
PostPosted: October 7th, 2009, 14:06
why? :?
PostPosted: October 7th, 2009, 14:21
Because there is some electrical parts which can't be removed,that's my last hope.
PostPosted: October 7th, 2009, 16:19
Just swapping parts at random -- especially if you do not have the proper tools and experience -- is a good way to lose your data for good.
Swap platters only if you have a motor or bearing issue.
It may have been totally unnecessary to swap heads. Please give the drive to someone who can accurately diagnose & fix it -- if you truly want the data.
Good luck.
PostPosted: October 7th, 2009, 17:26
didn't I tell you not to open it if you never did Raptors?
it supposed to click though
hamis wrote:
What now?
there is the answer in my first post
PostPosted: October 7th, 2009, 17:28
HDD Spaz wrote:
why? :?
Agree with jono.
Don't play more, because there will be no data for recover anymore....
Janos
Users browsing this forum: Google [Bot], runner978 and 264 guests
