 Post subject: another wd1600bevs victim
PostPosted: October 8th, 2009, 23:24
i had this hdd installed in an external usb adapter case the adapter board possibly shorted
the drive was functioning at the time ... then i smelled something and the control board was very hot
i got a set of drives for swap part boards they seem to be worse than the drive i have the all click then are silent
but when i swap the closest serial pcb to my drive it spins up normal but still wont show up in bios
i tried to get hmdd but wont see the drives either (bios would need to see also correct ?)
stored data drive
wd1600bevs-00rst0 no sound warm to touch
when i swap pcb from drive 1 sounds normal
parts drives
1 wd1600bevs-00rst0 clicks
2 wd1600bevs-60rst0 clicks
3 wd1600bevs-22rsto clicks
if someone could point me in the right direction for backing up as much firmware romage as i need .
i searched but couldn't find what program was used to make the restore in the firmware downloads (hopefully i dont need that prom adapter)
the data on this drive isnt super critical im just not sure what all was on the drive if i could at least get a look at the directory
and im learning more that i ever thought there was to know about hdds
 Post subject: Re: another wd1600bevs victim
PostPosted: October 9th, 2009, 0:41
Without specialist equipment you will not be able to deal with the ROM on these, as it is stored in the MCU.
PostPosted: October 9th, 2009, 2:35
Apart from moving a BGA chip, "something else" may be fried too.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 232 guests
