 Post subject: Need ST9320421AS SD13 firmware
PostPosted: October 16th, 2009, 12:24
I there :)
I have a Seagate ST9320421AS drive and sometimes it makes a strange click. From what I read, it is a known problem and it is solved in SD17 firmware. That firmware is for ST9320421ASG drive but works in ST9320421AS. I upgraded my drive’s firmware to SD17 and it is true that it makes less “clicks” but when it clicks the computer hangs a little bit and I’m afraid that it damages my drive.
So, can someone upload the SD13 firmware?
Thanks for your time :)
 Post subject: Re: Need ST9320421AS SD13 firmware
PostPosted: October 16th, 2009, 12:32
Backup your data and replace the drive. It may not be just a firmware issue.
PostPosted: October 16th, 2009, 12:39
Back up and get a new drive.
www.datarecoveryne.com
PostPosted: October 26th, 2009, 15:10
I don’t think replacing the drive is going to solve my problem (ok, probably it solves my problem but is not what I want :) ). I have a ST9320421AS drive and now it is recognized as ST9320421ASG so, for now, it lost the warranty. Besides, the drive makes an annoying click with SD13 firmware but works well.
I know I should had made a backup from the original firmware… it is like the old story, “read the manual after breake the device” lol
If there is someone that could upload the SD13 firmware or a newer version for ST9320421AS (not the ST9320421ASG) would be great :)
Users browsing this forum: Google [Bot] and 244 guests
