 Post subject: PC wont booth with my seagate barracuda 7200.9
PostPosted: October 28th, 2009, 1:33
Hi, I need help on my HDD.
It happened when i got a "classified virus". I scanned it with kaspersky and it worked. Now the problem is it doesn't boot anymore and it keeps restarting from post, and i did some repair from the my installer cd and do the fixboot, chkdsk, and fixmbr but unfortunately it didn't work. I also tried the disk to other computer with same board but nothing happened, it can bee seen as slave also. So can you please help with these?
Thanks.
 Post subject: Re: PC wont booth with my seagate barracuda 7200.9
PostPosted: October 28th, 2009, 3:01
if your data is not important, than use MHDD, and de-activate the MBR.
Than boot up to windows, re-initialize the disk, and format it.
Janos
PostPosted: October 28th, 2009, 3:16
Yes my files are important and im hoping not to format it right away, do you have solutions for this.. BTW Thanks for the reply.
PostPosted: October 28th, 2009, 3:33
Try to connect it to other computer and try to copy your data.
data recovery Poland
PostPosted: October 28th, 2009, 5:00
If your data is important, the best suggestion is, try to find a pro near you.
This case can't be too expensive, i think.
I can imagine only one easy step, what you can try before sending to pro:
Try to mount readonly mode under linux....
Janos
Users browsing this forum: No registered users and 86 guests
