 Post subject: Help with a WD5000BEVT-00ZAT0 with a burnt out circuit board
PostPosted: October 28th, 2009, 23:49
I have a Western Digital 500GB Laptop drive: WD5000BEVT-00ZAT0 with a burnt out circuit board.
I ordered a drive with a matching PCB:
BAD: 2061-701572-400 AB XT 7T05 6LXW 2 0006280 9 286
GOOD: 2061-701572-400 AB XT 7T05 6FJ2 3 0006280 9 286
The Bad drive will not spin with the Good circuit board.
The Good drive works with the Good circuit board.
I checked the motor resistance and both drives are the same.
The bad drive makes no noise with the Good circuit board and draws .25 amps.
I even tried a hot swap. The bad drive will not spin, beep, buzz or make any noise at all with the good PCB
What do you think is wrong?
 Post subject: Re: Help with a WD5000BEVT-00ZAT0 with a burnt out circuit board
PostPosted: October 29th, 2009, 0:10
ROM?
Zero Alpha: zeroalpha.com.au
PostPosted: October 29th, 2009, 0:18
You can't swap pcb's on this model without reprogramming the rom, but it shoud spin with the good pcb and not ID. Head stiction or preamp is my guess.
PostPosted: October 29th, 2009, 0:19
The good circuit board will make the good drive spin and go to ready so the ROM must be good.
I can reprogram the ROM but the good PCB should spin the bad drive.
The only thing I could think of is maybe a head or preamp is burnt out on the bad drive and the firmware checks for good heads before turning the motor on.
Anybody know if this could be true?
I would think it would make some kind of noise if the head was stuck.
PostPosted: October 29th, 2009, 1:28
You should check this in kernel mode.
PostPosted: October 29th, 2009, 10:55
hi,
have you swap ROM chip first? install and check voltage after give power?
data recovery service[/b]
PostPosted: October 29th, 2009, 12:27
If PCB is faulty it should still power on with donor PCB attached, even if it cannot show ID. If Stiction or motor is damaged then on attempting to power on there should be some faint sounds from the resistance caused by incorrectly parked heads and/or frozen motor. Are you absolutely sure with donor PCB on there are no sounds from within the HDD?
PostPosted: October 29th, 2009, 23:12
I brought it into a quiet room and put my ear right to it.
Not a sound.
When I power the PCB alone (not attached to the hard drive) it draws .3 amps.
When it is hooked to the bad hard drive it also draws .3 amps.
The connection seems ok between the PCB and the motor.
I am running it on a $500 regulated power supply set to exactly 5 volts.
PostPosted: October 30th, 2009, 3:50
You are going to need help with this .. You have more than a board problem. Could you photo the component side of the board ..
Where are you based?
https://www.mjm.co.uk/
PostPosted: October 30th, 2009, 9:38
If the preamplifier is damaged or fails to operate - This Hard Drive is not spinning up...
Mikippp
PostPosted: October 30th, 2009, 10:38
[The Bad drive will not spin with the Good circuit board.]
Like mikipp said maybe the shortcut damaged the preamp too i had check that on this series if damaged preamp the hdd not spin, that looks like some IBM 3.5 cases where doesnt spin“s caused by a shortcut on preamp
PostPosted: October 30th, 2009, 16:29
I have just done a WD2500BEVT and a WD3200BEVT maybe this helps.
1) If Rom is corrupted the drive will not spin.
2) Also I have had several BEVT in the past with bad Q1.
3) If heads or firmware are bad, drive will still spin with a donnor pcb.
4) not sure about preamp
i thing your problem is either preamp or stuck heads and or stuck spindle. But not ROM or Firmware.
PostPosted: October 30th, 2009, 23:53
There is nothing wrong with the ROM on the good PCB because the good drive goes ready with it on.
If the firmware on the drive does not match the firmware on the PCB it should still spin.
The servo chip on the bad PCB was burnt bad and it could have taken out the preamp.
I would say #1 Preamp #2 stuck head or bearing.
I have to see if the customer is willing to pay for a clean room recovery.
I told him it would be a simple PCB swap.
I will let you know what happens.
Users browsing this forum: No registered users and 92 guests
