 Post subject: Seagate ST31500341AS shows wrong ID
PostPosted: November 11th, 2009, 22:44
hi all
i have the above drive that is spinning up, clicking a couple of times and then spinning down, but getting ready.
the drive will then show the wrong ID, firmware, serial and capacity
trying to enter terminal does not give anything,
the drive lable is ST31500341AS
firmware CC1H
the drive is showing under PC3000 as
ST-Ml3fqbl
QNR-bfw( incorrect serial number)
1117F38F( incorrect firmware)
3.86GB
just wondering if anyone has come accross this for this drive. can this be a head issue ?
Thank you
 Post subject: Re: Seagate ST31500341AS shows wrong ID
PostPosted: November 11th, 2009, 23:50
heads are bad with probability of 90%
PostPosted: November 12th, 2009, 0:01
Hi doomed
thankyou fir reply. I suspected so, but why can't I access terminal mode , isn't that from pcb
thankyou
PostPosted: November 12th, 2009, 1:42
I was facing same same problem in Seagate 500 GB Es.2 No access to terminal. I have suspect Rom Issue. Even changed the PCB abut No Success. Even if I put it on Doner Disk Doner shows Garbage detection. but both disks were spinning and initializing. perfectly. Retured the disk back to customer :(
DF :)
DF :)
www.datatracksystem.net
PostPosted: November 12th, 2009, 11:40
Termainal is blocked in this FW until the drive inits fully (which is not going to happen with bad heads)
Users browsing this forum: Majestic-12 [Bot] and 142 guests
