 Post subject: Frustrating WD800 Unicorn!
PostPosted: November 11th, 2009, 21:28
I've been working with a WD800JD Marvel series Sabre 58 drive (xxMUxx).
It clicks and spins down.
1. PCB has been changed. No difference.
2. Heads have been changed - at least 3 different sets. No improvement.
3. Donor heads all work when put back in original drives, so no media damage.
4. Hotswap never works - only clicks and times out
5. Micro jog on swapped heads is close enough
About the only think left to try . . . is to put the platter in another enclosure. I'm reluctant to do that chielfly because I don't think it will make a difference.
Am I wrong? Has anyone gotten one of these back on track by swapping the motor?
Any suggestions of something else to try before I give up?
Thanks!
http://www.datasaversllc.com
 Post subject: Re: Frustrating WD800 Unicorn!
PostPosted: November 11th, 2009, 21:32
Unicorns are PITA
You did good but I think it's just heads
PostPosted: November 11th, 2009, 22:07
Jono, check PM
PostPosted: November 12th, 2009, 1:45
Thank you very much!
PostPosted: November 12th, 2009, 8:16
I have the same problem also with unicorn and sabre too.
any help will be appreciated.
thanks
PostPosted: November 12th, 2009, 11:55
I have the problem jono!
I desesperate! I have tried everything with PC3000 too and nothing... also the hotswap doesnt work in my case...
Any idea?
Thanks!
PostPosted: November 12th, 2009, 13:19
Jono wich model WD800JD-22LSA0? if its this model contact me on PM we did month´s ago some head swap on this model with sucess
Users browsing this forum: Hardcore Games and 217 guests
