 Post subject: i need firmware for maxtor diamondmax 16 4r160L00
PostPosted: November 14th, 2009, 20:31
hello Guys i have problem with maxtor
diamondmax 16 model 4r160L00 code: RAMB1TUO N,M,G,D SN: R421BQGE 160GB ATA/133 HDD
the HD don't work and is seen in BIOS like Maxtor FALCON
i need firmware and loader
Thank you very much
 Post subject: Re: i need firmware for maxtor diamondmax 16 4r160L00
PostPosted: November 15th, 2009, 0:00
What tools are you using to work in the SA of this drive. If you need help contact BlackST by pm he is in your area and might be able to help you out on this one.
Tell us what tools you have so we can see if we have what you need in FW and ldr files
Iorana Haraharaini
PostPosted: November 15th, 2009, 9:37
i have found the firmware for my maxtor but it is file .pcr i need file .ldr thanks
PostPosted: November 15th, 2009, 10:58
If you are using PC-3000, import the PCR file into your database....
Data Recovery Ireland
PostPosted: November 15th, 2009, 11:10
i have pc3000 but i don't know to proceed thanks
PostPosted: November 15th, 2009, 11:38
:shock:
What do you want to do exactly ? repair ONLY the drive loosing data OR recover data ?
PostPosted: November 15th, 2009, 11:44
i want to repair my hard disk with firmware broken
PostPosted: November 15th, 2009, 11:54
Parlo ANCHE italiano : ti interessano i DATI o vuoi solo che RIFUNZIONI e non importa se perdi i dati ?
Inoltre : mi sa che non puoi importare il file .PCR .
Che vuol dire "non so come procedere" ?
I speak ALSO italian : you need DATA or you want to have only a working drive regardless of data ?
Moreover : you cannot import .PCR
What does it mean "don't know how to proceed" ?
PostPosted: November 15th, 2009, 14:29
voglio solo che rifunzioni grazie
Users browsing this forum: Bing [Bot], Google [Bot] and 70 guests
