 Post subject: Seagate 7200.10 very slow read
PostPosted: November 16th, 2009, 14:51
The drive in question:
Seagate 500GB 7200.10
ST3500830AS
9BJ136-100
FW: 3.AFD
SITE: TK
The problem:
The drive reads all sectors very slowly >500ms. Every sector is accessible but can often require a retry. Essentially the drive needs time to become ready again between reads. It does not strike me as a degraded media/bad sector issue. I've disabled read ahead on the extractor but does not make a difference.
Firmware is OK and fully readable, no head mask errors in the command console.
I've swapped over the PCB with a exact match donor. Drive becomes ready as normal, but the slow read issue is the same. Any suggestions?
I'm just about to attempt to reverse clone. i doubt this will make a difference, but will post if it does.
Best wishes,
John
CDR - Manchester Data Recovery Services
0161 408 4857
http://www.cheadledatarecovery.co.uk/
 Post subject: Re: Seagate 7200.10 very slow read
PostPosted: November 16th, 2009, 16:22
what is the terminal output?
PostPosted: November 16th, 2009, 17:00
sounds like CE Log errors issue to me
PostPosted: November 16th, 2009, 17:14
I had the same thoughts...
PostPosted: November 16th, 2009, 17:15
Does it make little "chirping" sounds while reading by any chance?
PostPosted: November 16th, 2009, 19:35
Same thought here, therefore I wanted to see the terminal log to confirm.
PostPosted: November 16th, 2009, 19:39
if you can post terminal.
ZeBong
" Россия еще раз"
PostPosted: November 17th, 2009, 5:06
Yes, should have checked before, looks like CE log errors. Here is the output, I have not pasted all of it as it keeps going on and on...:
Reset
4096k x 16 DRAM
GALAXY - 1_Disk S-6D 09-22-06_15:48
HM SFI
(P)SATA Reset
AT Er 00 Nwt Er 37 RdWr 15bbd.02.01fc
ATA St 50 Er 01 Op 00 0,0000/0/00,00 01 00
Niwot: 97f29ff7 b8 97f29ff7.1.840 0000 005f 0000 0000
DiskAccess ReadSector EC=43 at 015bbd.02.01fc
CE Log ErrCode=37 LBA=2ad8be5c Type=5 Add To Pending 2ad8be5c
CE Log ErrCode=37 LBA=2ad8bc60 Type=6aAT Er 00 Nwt Er 43 RdWr 15bbe.02.0005
Niwot: 97f29ff7 b8 97f29ff7.1.840 0000 005f 0000 006a
CE Log ErrCode=43 LBA=2ad8c0e8 Type=4 Remove from Pending 2ad8c0e8
AT Er 00 Nwt Er 37 RdWr 15bbe.02.012c
Niwot: 9ff79ff7 b8 9ff79ff7.1.840 0000 005f 0000 006a
DiskAccess ReadSector EC=43 at 015bbe.02.012c
CE Log ErrCode=37 LBA=2ad8c20f Type=5 Add To Pending 2ad8c20f
CE Log ErrCode=37 LBA=2ad8c0e3 Type=6aAT Er 00 Nwt Er 43 RdWr 15bbf.02.03bf
CE Log ErrCode=43 LBA=2ad8c925 Type=4 Remove from Pending 2ad8c925
CE Log ErrCode=43 LBA=2ad8c566 Type=6aAT Er 00 Nwt Er 37 RdWr 15bc0.02.0412
DiskAccess ReadSector EC=43 at 015bc0.02.0412
CE Log ErrCode=37 LBA=2ad8cdfb Type=5 Add To Pending 2ad8cdfb
CE Log ErrCode=37 LBA=2ad8c9e9 Type=6aAT Er 00 Nwt Er 37 RdWr 15bc1.02.022b
DiskAccess ReadSector EC=43 at 015bc1.02.022b
0161 408 4857
PostPosted: November 17th, 2009, 6:01
Yes definitely a CE Log error; I've removed the CE Log and now the drive is cloning nicely.
All the best,
John
0161 408 4857
PostPosted: November 17th, 2009, 18:57
That's it!!
PostPosted: January 29th, 2022, 6:59
All the best,
John
HOW ??
ANY METHOD TO READ IT IN MRT . ?
Users browsing this forum: No registered users and 65 guests
