 Post subject: WD800BB-55HEA0
PostPosted: November 16th, 2009, 22:11
MDL:WD800-55HEA0
DATE: 23 JUN 2004
DCM: HSBHCTJAH
Part number on PCB is: 2060-001130-012 REV A
And there's also a number on bar code tag: 2061-001130-300 AF
PCB is burnt by power supply. What kind of PCB can be used for replacement? I searched before I post this, it seems nobody has this model.
Appreciate.
 Post subject: Re: WD800BB-55HEA0
PostPosted: November 17th, 2009, 21:28
Caviar Families, u could tried reprogramming Donnor PCB with patient ROM, should be usefull with same numbers at PCB 2060-71292-000 REV A for example, if knocks that means damanged inside HDA
PostPosted: November 18th, 2009, 4:05
hi,
i have this PCB in stock. please contact me by email if still need it. thanks.
data recovery service[/b]
PostPosted: November 18th, 2009, 19:18
Thanks, beto.
But I have a question, PCB 2060-71292-000 REV A looks so different from mine, are they compatible? I read some posts about the rules, it seems I should use a PCB with same part number, am I right? Could you please explain this? Thanks.
PostPosted: November 18th, 2009, 19:34
is an example the pcb that beto told you.
you can try with that one or similiar.
ZeBong
" Россия еще раз"
PostPosted: November 18th, 2009, 21:43
it must be ===> 1130
Users browsing this forum: No registered users and 354 guests
