 Post subject: Seagate barracuda 7200.10 dropped and beep
PostPosted: November 20th, 2009, 10:58
Hi all, I've just found this forum, and it's great!
First of all, sorry for my english...
Some days ago my 320 Gb portable HDD fell to the ground.
Now, hearing its sound, it starts up, but after few seconds it beeps, then stops and restarts. And so on.
The drive isn't recognized from bios. I've tried also to remove it from the case and connect it directly to the mainboard. But it doesn't work.
After some researches on this forum I've understood that the problem could be something about bearings. I think there's no hope, but I make a last try:
There some hope to solve the problem DIY or I can use the disk as fresbee?
(I don't want to pay a pro to recover data, there aren't very important data...)
Thank you!
 Post subject: Re: Seagate barracuda 7200.10 dropped and beep
PostPosted: November 20th, 2009, 11:00
Frisbee!
PostPosted: November 20th, 2009, 11:03
99.9 percent frisbee material m8. Sry.
PostPosted: November 20th, 2009, 11:04
neither soldering iron or screw-driver or bruteforce could save it? :)
only a pro?
PostPosted: November 20th, 2009, 11:09
Well a russian guy can fix it with brute force and a saw. U seen how we fix space stations in Armagedon. +))
PostPosted: November 20th, 2009, 11:15
:D
okok... so I'll destroy it.
Thank you guys for the support!
Users browsing this forum: Google [Bot] and 254 guests
