 Post subject: hdd recovery laptop -quick IDE/SATA connect recommendations?
PostPosted: December 15th, 2009, 0:23
Hi everyone, I am interested in making a mobile hdd recovery laptop I can bring with me to customer sites.
Does anyone know of a quick and easy way to connect an IDE/SATA drive to a laptop via some connector commercially available? A USB caddy wont work for obvious reasons. ;)
 Post subject: Re: hdd recovery laptop -quick IDE/SATA connect recommendations?
PostPosted: December 15th, 2009, 2:43
Why wont a caddy work or even the customers home computer..? as in home data recovery is only going to solve basic problems anyway.
Zero Alpha: zeroalpha.com.au
PostPosted: December 15th, 2009, 5:55
No problem if you use one of the newer Laptops with a SATA /eSATA connector for external HDD.
For Laptops without that its possible:
1. If internal CD/DVD is old IDE conntector - there exist bays for 2nd IDE-HDD instead of the internal DVD
- you could use extension cord connected into such a bay plus an external power adapter for an external
HDD plus adapters for 2,5" to 3,5" and/or IDE to SATA converter - whatever necessary
2. If internal CD/DVD is a SATA connector - there exist SATA+power cable extensions.
But for 3,5" drives you definitely would neet extra power adapter
For IDE HDD you would need additional SATA to IDE converter
If its about time - spent at the customers office - there is only one tool I am aware of to
cover your request (professionally): Atola Ethernet
No doubt, its not that small tool - and one of the expensiver ones - but:
- connectable via the ethernet port to the laptop
- you may connect source and a target HDD directly to that tool
- you are able to image at maximum speed from source to target
- you have a full range of tests available
- you can repair FW of a wide range of HDD
- you can access files of found ntfs partitions to recover them
PostPosted: December 15th, 2009, 20:50
Thanks falther! I dont know why I didnt think of this. I ordered the drive caddy and the extension cord.
Users browsing this forum: Majestic-12 [Bot] and 235 guests
