 Post subject: Seagate spindle seizure
PostPosted: November 28th, 2009, 13:35
Anyone knows could bearing removal by Sergey Yatsenko method work on Seagate Barracuda 7200.8 ST3300831A? Or its only for IV?
Any other method beside platter transplant and turning spindle tool maybe? Tried to free it, but could only spin the platters with force and heads are not stuck...
Reševanje podatkov - Tannaris
 Post subject: Re: Seagate spindle seizure
PostPosted: November 28th, 2009, 14:46
Wow do you have the proper tools and clean room to do this job with. Seagate alignment of platters is not an easy one or even head change on these drives. You need special tools and know how to do this one. Seem to me you data is not important to you and you have now lost a lot of your chance to ever find it back again. Others here have done as you and now their platters are either smashed into a thousand pieces, or are used for making art pictures.
Iorana Haraharaini
PostPosted: November 28th, 2009, 15:38
I have laminar bench, some tools...data is not important here, its training by trial and error and documenting :wink:
PostPosted: November 28th, 2009, 16:03
hi,
We have tooling to solve such cases.
U can PM me if interested.
PostPosted: November 29th, 2009, 1:30
You can search here on the forum there is a spindle motor tools that was desinged by a DR company and still might be available to purchase. Also you can search there is another company who has designed head swaping tools to use on this drive. Good luck on your research on this one. But try to make a tool for you to use in the head swaping of this drive multiple heads need to be kept aligned in order to guarantee sucess.
Iorana Haraharaini
 Post subject: Seagate ST31000340AS
PostPosted: November 29th, 2009, 5:16
Good Day
i have also same problem with Seagate ST31000340AS FW:SD35 motor was jammed i release with
some tools now motor is Rotating but when i plug power on it's not moving do i need to swap platters? i don't have head Removal Tool for this HDD if some one knows which tool is good plz let me know Thanks for any comments.
PostPosted: November 29th, 2009, 5:45
You need Professional help on this one. You must stop right there .
If you continue like this you lost everything .
PM if you want Pro Help.
XRONIS
T3 Professional Data Recovery
http://www.t3-recovery.com
Users browsing this forum: No registered users and 94 guests
