 Post subject: Why did the seagate 7200.11 fixed worked only a short time?
PostPosted: November 30th, 2009, 12:53
ok, lets say i do have head problems like some dr company i sent too the drive after trying the fix, said.
ok,
so, how come i had a dead unrecognized hdd and right after i finished the fix it was instantly recognized and i could see all files in dos.
when i conected the hd to a vista pc as secondary hdd it showed only d: and when i tried to copy d it stoped after 5-10 mins and wouldnt be recognized again.
something doesnt add up.
if i had bad heads, head crash, the fix shouldnt do anything.
if i had the firmware issue the fix should have lasted.
any ideas?
something i found later as i printed the output of the terminal
in the end when you get:
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 00C8
User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 00000080, Elapsed Time 0 mins 05 secs <----- didnt get this line
User Partition Format Successful - Elapsed Time 0 mins 05 secs
i didnt get the middle line only the first and last, does it mean anything?
 Post subject: Re: Why did the seagate 7200.11 fixed worked only a short time?
PostPosted: November 30th, 2009, 13:00
any ideas?
you might have some other problem besides firmware issue.
it happens very often, when drive has more than one problem.
www.datarecoveryne.com
PostPosted: November 30th, 2009, 13:01
How many threads are you going to make about this one problem?
Your disk had the firmware problem, likely triggered by other problems with the drive (in your case bad/failing heads). You were able to repair the firmware issue, but still were faced with the problem of bad/failing heads. After a bit of use the bad/failing heads triggered the firmware problem again.
PostPosted: December 1st, 2009, 3:49
you basicly took my question and formed it as an answer.
i am looking for somone who has expiriance to guess why doing a firmware fix (to the pcb) would revive completly a hard drive enough to copy from it for a short time and then be unrecognized again. if the heads where failing how come i could copy for 10 mins?
can a refix do it again?
what does your dr expiriance tell you.
PostPosted: December 1st, 2009, 4:23
mutiple problems causing the situation more complex. Weak/damaged heads with the damaged FW... You may do a quick FW fix but the damaged head will cause your drive from not coping data and back to the FW issue again.
PostPosted: December 1st, 2009, 11:17
Firmware has nothing to do with the PCB. You don't understand what is happening because you don't understand how your hard drive works. Do yourself a favor and read through some of the eleven billion old threads about this problem instead of making eleven billion new ones about your one case.
PostPosted: December 1st, 2009, 18:59
Dont try access to data in windows... make Data Copy with DE.
Users browsing this forum: Google [Bot] and 44 guests
