seagate 1tb
December 3rd, 2009, 10:41
hi ,
i have 1tb seagate sata harddisk it spin nomally but doesnot detect , i change logic card but it start clicking sound. how can i update this firmware.
Re: seagate 1tb
December 3rd, 2009, 10:46
Which exact model and firmware revision?
Sounds like common firmware fault
Re: seagate 1tb
December 3rd, 2009, 10:57
but how can i update fimware or any utility do you have
Re: seagate 1tb
December 3rd, 2009, 11:10
check the model, some seagate are known for an issue such as this.
chack the hard drive label and write what it says.
Re: seagate 1tb
December 3rd, 2009, 11:23
common problem. u need terminal to fix it.
Re: seagate 1tb
December 3rd, 2009, 11:36
plenty of threads on here giving you step by step on how to fix that problem
Re: seagate 1tb
December 3rd, 2009, 12:02
You need to troubleshoot the fault correctly before attempting a repair.
Again, what exact drive and FW Version??
Re: seagate 1tb
December 3rd, 2009, 12:56
You've changed the PCB (presumably without transferring the ROM), that's why it's clicking.
